Results 1 to 15 of 15
    Normal lang ba talaga sa inyo ang may tagas ng oil on any part of the engine? Ako kasi, I make it a point na malinis ang engine bay ko and free from leaks. Kasi mukhang hindi na maiiwasan considering that my truck is already 8yrs old.
    The leak is found underneath, dun sa may pinagkakabitan nung oil pan sa makina? Anyone encountered this already? What do I need to do? Hindi naman siya actually malakas coz hindi naman tumutulo.
    Another problem is my oil sending unit...kapapalit ko lang, namamasa nanaman ng langis :confused:
    Kung nagpapawis lang, pabayaan mo na muna. Don't worry about these things too much.
    You should see my engine...
    djerms,
    parehas tayo ng problem and fortunately (and hopefully) nakita din kung saan galing tulo ko.
    you should see my parking, grabe, parang nagla-lawa na sa dami ng tulo.
    anyways, through the recommendation of a friend, i brought my gen1 pajero sa nodalo's at sucat.
    the mechanic initially diagnosed that there's a leak in the oil pan and the crankshaft oil seal. they then advised me to have an engine underwash (P50 only shell infront of their shop) first and brought it back to them.
    the verdict: oil leak coming from the oil pressure sending unit (P730 from a nearby auto supply) and the breather hose are causing the oil to scatter/ spread under the engine.
    they replaced the oil pressure sending unit (i had the big bulb type), replaced the oil breather hose with a longer one.
    i'm still praying that the leak would not come back.
    Bogart,
    Oil sending unit ba ang sinasabi mo? Yung may nakakabit na wire? Yun din ang malimit na problema ko. Kakapalit ko lang, ayun, meron na naman.
    Hindi naman tumutulo sa sahig ang oil ko pero may traces na ng oil kung saan naka bolt ang oil pan sa engine.
    Otep,
    Nagpapawis din ba yung oil pan mo? Yung sa akin naman traces lang ng oil where the oil pan is bolted sa makina.
    I recently had my oil changed and iniisip ko na baka naman tinulan lang pagkatanggal nung oil filter. pinunasan ko last night and after parking this morning I checked again, so far tuyo pa rin naman.
  5. FrankDrebin Guest
    Hindi kaya yung half moon? Ah oo nga pala sa ilalim nga pala. :D
    Hindi kaya yun yung kapag nag-change oil ka eh yung natuluan, nadaluyan ng oil or something like that.
    Frank,
    Sana nga natulutan lang. Tinitingnan kong mabuti last night ala CSI. Posibleng natuluan pero nagtataka ako kung bakit yung ibang parts na dapat matuluan, hindi naman natuluan. Ay ewan. Mabuti na yung sasakyan ko nalang ang may tulo..wag lang ako..hehe.
  7. FrankDrebin Guest
    Masarap naman yung feeling bago magkatulo hehehe.
    Kung namamawis lang at hindi naman tumutulo sa sahig, ok lang yan.
    Yun oil sending unit ko sa Isuzu Parts Caloocan ko binili. Nagulat nga ako kasya pala sa 4D56. Ok lang yan tulo na yan. Baka naman sobra lang ang oil na ilagay kaya nagkalat sa oil pan. Pero ok lang yan. ;)
    Afrasay,
    Yung sa oil sending unit ay hopeless case na yata.
    Frank,
    Lagyan ko kaya ng antibiotic ang makina ko..hehe.
    Dec 2009
    baka meron makatulog jan... nag lagay ako ng silicon oil sa fan so binaklas nun talyer. pag uwi ko check ko garahe wow may tulo sa sahig na trace ko agad galing dun sa kinakabitan ng mga belt yun main na umiikot
    any idea san lumalabas yun oil? crank?
    nag luluha lang po yun oil hindi ganun kalakas
    sa oil seals ng pulley yan. need mo open timing belt cover to access it. And while you're at it, replace mo na rin timing belt/tensioner if di mo pa napalitan for the last 80,000km. Replace all oil seals para isang trabaho lang. Mura lang yan.
    Dec 2009
    ^ sir salamat sa reply na sold ko na yun adventure ko hehe prob ko ngaun is tong local space gear ko na may tulo rin haha
    hahahaha 4D56 pa rin ang engine.
    Jun 2004
    usually its the balancer shaft oil seals for me..get genuine oil seals from eldorado. that should solve it
4d56 peeps and to others who can help...
