Results 1 to 10 of 24
November 29th, 2008 12:37 AM #1
fellow tsikoteers and gurus.
what are the signs/symptoms na may loose compresion na ang cylinder mo?
diesel yung suv namin (4jx1 trooper crdi)
namamatayan kasi ako minsan kapag nag babacking kahit na AT naman ang tranny ko.
i also expiriencing sobrang black smoke kahit 1 month ago palang ako nag pa PMS ng Royal purple na im using for about 6 months narin.
black smoke lumalabas kahit bagong linis air filter ko. (K&N filter konting oil lang naman nakalagay and 1 year ko ng gamit 4 times na ako nag lilinis)
i do also expirience some vibration during idle.
san pwede mag pa compression test? yung reliable and may alam na shop and may expirience na on 4jx1 engine.
mileage of the trooper is 80K
TIA
November 29th, 2008 02:35 AM #2
sorry to hear... I'll just share some few info... hope it helps.
good luck!Last edited by rion; November 29th, 2008 at 02:38 AM.
November 29th, 2008 07:37 AM #3
November 29th, 2008 09:59 AM #4
Hard starting is a good sign.
Wierd idle is another.
Pumping oil. Can be checked via oil consuption.
Isuzu ang may capability for diagnosing but a person with tech2 and knowsw to interpret codes and reading can help.
May MIL ka ba?
November 29th, 2008 10:20 AM #5
:hi: 4jgtootsie
starting is the same walang pinagbago/
oil consumption? so far hindi naman nagbabawas.
what is a MIL anyway?
and can too much oil cause this?
parang nadamihan kasi ng kaunti yung nalagay na oil pero hindi naman lagpas dun sa level sa dip stick. mataas lang ng kaunti pero nasa range naman.
and yes, weird idle nafifeel ko minsan. parang action mag stall yung engine (biglaan mo mafeel) then biglang ok na. pag nag babacking lang talaga ako namamatayan. thank god once palang nangyari.
November 29th, 2008 10:39 AM #6
MIL is another term for check engine light but the actual meaning is Malfunction Iluminating Light another and related is DTC Diagnostic Trouble Code.
Be extra careful when checking the oil level watch its viscocity and smell.
4JXI has a dangerous habit of spilling diesel fuel to the oil chambers via the o ring of the injectors once its failing.
November 30th, 2008 09:03 AM #7
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 30th, 2008 04:35 PM #8sj, if the oil level is with the high and low of the dipstick it should be ok. lumagpas ba?
November 30th, 2008 06:14 PM #9
nope migs.
its within the range naman. almost the same naman sa previous level before ako nagpa PMS.
and same amount din naman yung quantity ng oil na nilagay nyo. 7 and 1/4 to 1/2 liter naman, hindi umabot ng 8 litres.
palagay ko it has nothing to do with the recent PMS kasi mga a week or 2 pa after ako nagpa PMS lumabas ang sakit na to.
loose compresion kaya?
what are the remedy for a loose compresion?TIA.
December 1st, 2008 10:13 AM #10
migs, mejo lampas siya sa operating range ng kaunti . . .
what should i do?
TIA
i didn't know differential oil can be... picky. when my 2005 innova swam thru ondoy, i had its...
