Results 1 to 10 of 26
January 28th, 2005 06:28 PM #1
Hello,
Hingi lang ako comments on using semi-synthetic oils on diesel engines. I currently use regular oil on my diesel ride pero parang gusto ko i-try yung semi-synthetic. Semi-synthetic lang kasi I find the fully-synthetic oils too expensive e. Also, even if I decide to change to semi-synthetic oil I still would want to change it regularly at 5K intervals.
Lastly, I have read somewhere that when you switch to synthetic oil you will not be able to go back to using regular oil? Is this true?
Thanks!
Tsikot Member Rank 3
- Dec 2002
- 636
January 29th, 2005 08:49 AM #2Most semi-synth oils use a mineral base oil plus synthetic additives so the advantages of synthetic oils is not really realized. If you're changing every 5k km, then just stick to a good mineral oil.
Haven't seen any problem switching from synth to mineral again- i've done it.
February 24th, 2005 04:58 PM #3
meaning not really advisable to shift to semi-synthetic..... rather mineral oil na lang * 5k maintenance..... all the while i thought this semi-syn is better than mineral.....
February 24th, 2005 05:17 PM #4
Semi-synth is better than mineral in a lot of aspects. But if you regularly change your oil every 5,000 kms then it's not really worth the added expense.
February 24th, 2005 05:27 PM #5Originally Posted by OTEP
February 24th, 2005 05:32 PM #6
Per'tua is an additive. NO, I would not buy it. Nor would I pour one in my engine if they gave it to me for free.
February 24th, 2005 05:47 PM #7
otep..... thanks! thou there is this new packaging that says "semi-synthetic engine oil" daw and not an additive...
July 10th, 2005 10:50 AM #8
bakit lumalabas nanaman tong PERTUA OIL ads dito sa pampanga...
its not the additive but its a SEMI SYNTHETIC OIL
more info --> http://www.pertua.com/products.asp
for the diesel engines they have the 20w-50 & 15w-40
here is the info for the diesel engine...
PER'TUA EXELLO SUPERIOR MOTOR OIL
(For diesel engines)
The best lubricant formulated with a patented oil and metal treatment technology that provides the engine excellent shield against wear caused by friction, heat, corrosion, abrasion and impact, and at the same time boosting performance efficiency. Being an anti-oxidant, its chemical stability and normal physical properties parameters are constantly maintained and lasts three to four times longer than the normal life of leading motor oils in the market.
Keeps engine parts highly protected even at the extreme conditions because of its high viscosity index or highest working temperature.
Meets Isuzu, Hino, Fuso, Mitsubishi, Toyota, Honda, Mercedes Benz and Volkswagen API passenger car requirements. Exceeds the highest service category of Cl-4 to sustain engine durability where exhaust gas recirculation (EGR) is used and are for use with diesel fuels ranging sulfur content up to 0-5% weight. It can be used in place of CD, CE, CF-4, CG-4 and CH-4 oils. Exceeds performance requirements of Mack, Cummins, Navistar, Detroit, GM 6094M, Ford ESN-M2C121E, ESE-M2C153G and F.
Grades available:
20w-50 & 15w-40
Packaging
Packaging of Per*tua Exello Superior Motor Oil is, as follows:
1 liter bottle packed in cases of 24 bottles
4 liter plastic container
1 drum of 200 liters
[SIZE=3]
anyone tried this?[/SIZE]
- 135
- May 2005
- 286
July 10th, 2005 07:14 PM #10Ginagamit namin yang Per'Tua semi-synth oil sa Liteace namin, wala naman kaming naging problema. Although gas yun.
109,606 vehicles were sold in the first quarter of 2024 | TopGear PH
Car Sales Data (2024)
