Results 21 to 28 of 28
January 11th, 2004 12:45 AM #21
typical cone filter WILL work (marginally) but will require an elbow adapter to install.
- 71
January 11th, 2004 09:56 AM #22well, i don't get what you mean by an elbow adapter.
others had theirs fabricated. the one being attached directly on top of the carburator, then the connecting tube and finally the filter. i read somewhere that i could use the one used by an L300 carburated gas van. hirap lang maghanap. and i don't know what it is called.
January 11th, 2004 01:12 PM #23
An elbow adapter is what you need to run a cone type air filter. In theory a cone-type filter will work better because the pipe and filter can be routed away from the engine compartment.
February 1st, 2004 11:32 PM #24
May nagsabi sa akin na yung pangcarburator na air filter theres no increase in HP not like the fuel injected cars today....
Is there anyone who knows the solex single?
Im planning to buy this because someone told me its better and effective than the airfilter for carbs...
February 1st, 2004 11:43 PM #25
Solex ...AFAIK they make aftermarket carburators..dunno if they make air filters
if you replace your stock carb with those solexes and webbers, performance will definitely increase but with the expense of fuel economy.
February 2nd, 2004 12:00 AM #26Solex ...AFAIK they make aftermarket carburators..dunno if they make air filtersSolex ...
Which is better solex or the webber 40 or 45?...
- Dec 2004
- 2
May 7th, 2005 11:01 PM #27dude, i just recently bought a saucer type filter which i connected directly to the carb. of my civic94. is it ok to put an air scoop just above my hood to let cold air pass through my engine bay instead of having a cone type with some modifications?
May 8th, 2005 01:12 AM #28
Yes, a hood scoop will work. Just make sure you have some way of not letting in rain water. OEM hood scoops (e.g. on Mustang, Camaro, Viper) are designed to prevent water from contaminating the filter media.
sinabi moh! i hardly see my children now. when they were young, schedules were more predictable.
Traffic!
