san po ba may sand blasting services? and saan kaya ito mas mura.
need to have some engine parts, cleaned and sanded out. TIA![]()
Sand blasting is used on heavy course surfaces. Glass bead blasting is more often used on non critical engine parts for aesthetic purposes only.
Depending on bead size, air pressure applied, and the distance of the blasting gun to the workpiece, bead particles may imbed. Most OEMs don't recommend glass bead blasting on soft material like aluminum and bronze. Beads can also stick to greasy parts, and cause engine damage if not properly cleaned after the blasting process.
Remember, these beads are glass which splinter on impact, and have sharp corners.
Ingat lang.
We often use the bead blast on turbo shaft and compessor wheel.
What do you plan to bead blast?
Central Diesel 4113711 to 13
external parts like intake manifold, headers, valve cover, oilpan etc.
*4JGtootsie where do you have yours blasted? would you know the going rate is for such?
