Results 21 to 28 of 28
July 9th, 2013 06:25 PM #21
July 9th, 2013 06:42 PM #22
Hindi ganyan ung inaalok sa akin. Parang regular na rubber lang siya na kulay black.
July 9th, 2013 07:27 PM #23
ah... i see. copy. thanks!
i may find the cushions useful when i upgrade my rims to a bigger diameter in the future.
July 10th, 2013 10:41 AM #24
^ i dont think so sir, dapat spacer/lifter lalo na kung sasayad yung gulong mo, cushions will do nothing with the ride height
so, anyone who can help me please, a much better lifter/spacer other than the one sold in banawe?
salamat!
- Mar 2016
- 8
April 1st, 2016 12:13 PM #25tanong lang, may lifter kasi ako nakalagay sa likod ng oto ko. Pero nakukulangan pa rin ako. Pwede pa kaya maglagay ng lifter sa taas bale taas at baba may lifter ako? Thanks
- Jul 2019
- 1
July 27th, 2019 11:15 PM #26Ask ko lang din po, ung shock lifter po ba ay ginagamit para mapataas ngkonti ang lowered na sasakyan, toyota? gaano po kaya kataas? salamat
July 28th, 2019 02:11 AM #27
Corrected the exaggerated rake on a gen2 RAV with a pair of custom inch thick spacers that sat between the strutmounts & towers. Opted for milled metal. They're permanent & won't deform. Rubber would compress over time & throw alignment all over the place. To do this, strutmount lugs need to be swapped w/ longer 1s.
July 28th, 2019 04:50 AM #28
That's correct Sir. Yung black ay spacers fitted at the end of the coil springs for height adjustments. kung ilang inch ang dinagdag mo na spacer, sya rin ang taas ng height ng lift ng car mo. While yung kulay red naman ay iniinsert yan sa coils ng spring to help or aid on dampening the load. Tulong din yan sa pag handle ng load ng car mo lalo na kung full load ka ng passengers..depende sa quality ng rubber ay tatagal din and durability.
Sensing a hint of weakening on our 6yr old Thai Pana DIN74, went to the distributor to have it...
