Results 1 to 4 of 4
April 16th, 2010 02:33 AM #1
Last couple of weks ago, i had my alternator change due to that its not charging anymore, the alternator i replace is the exact model and type, after installing it, 1 click and car starts fine, then after couple of minutes driving, i notice that when i turn the a/c on while in full stop, everything is fine, but when i rev it and pass 1000 rpm and release the gas pedal the rpm goes down to 600 and it stays there for like 5 secs. Then it goes back up by itself.. But if am not use the a/c everything is ok.
We already check the voltage of the alternator and its giving out the right voltage, we use a digital reader and its normal with and without load.
My main issue here is why when i rev it then release it right away the rpm goes 600 and it stays there for 5 secs and back to normal.
Is this time to clean the throttle body and intake and all sensor?
Hope somebody here can help me out
ride is 1999-2000 civic manual 1.6 vtec engine
April 16th, 2010 12:50 PM #2
i would probably check the belt tension of the a/c pulley and the alternator.
i think your vehicle uses a single belt to drive both. baka too tight or too loose, causing unnecessary drag when you have a/c on.
April 19th, 2010 10:23 PM #3
April 20th, 2010 09:16 PM #4
update kolang po..
my mechanic check the tension of the belts, power pump, alternator, compressor..ok naman po lahat..
i think its time to clean the TB?
hinde kaya yung computer box may sira?
any inputs would be greatly appreciated..
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
