Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
    May 2004
    Quote Originally Posted by theshepherd View Post
    Pasakay mga bossing.
    Nissan Sentra ECCS, parang humihinga ang idle, goes up and down. Pag naka neutral then apak brakes, rpm goes down then engine stops. parang nasasakal everytime mag be-brake, patay makina afterwards, what Im doing is apak brake then apak gas at teh same time while in neutral para di mamatay ang engine.
    Cold or hot engine, still the same. breathing rpm.
    What could be the culprit?
    Thanks in advance!
    common yan sa sentra... bring it sa casa then let them scan thru CONSULT.... para hindi hula hula... previously nung may Nissan bayan pa they have this Meka EB sa casa then they will use Consult to scan you car for free... hehehe...
    Nov 2013
    Hi Theshepherd,
    yan din ang problem ko sa nissan ECCS kahit e adjust ko yun sa Idle up sa makina na connected sa aircon ganun pa din e2 trying to look computerize tune up kasi ECU and eccs (computer box) saan banda naka kabit yun ignition coil?
RPM goes up down up
