Results 1 to 5 of 5
- Feb 2012
- 6
February 21st, 2012 09:54 AM #1good day po mga boss... need help here for my mitsubishi adventure 2003. every time i start the car nag iidle yung engine nya rpm goes up and down. nanginginig na parang mamatay engine. pag nag ddrive na still shaking pero konti nalang but when i accelerate push all the way down the gas pedal parang walang hatak.. my rpm goes up pero walang hatak... need help here.. advised is highly appriciated..
February 21st, 2012 10:39 AM #2
gas po ba yan o diesel adventure?
kung gas, baka marumi ang loob ng throttle at mga sensors.
kailan ang huli mong engine tune-up?
- Feb 2012
- 6
February 21st, 2012 04:55 PM #3gas po, manual last week lang i went to the mechanic to check everything regarding sa problem they cleaned everything including fuel injection and pinalitan din nila yung fuel filter.. nung ni road test namin ok naging ok naman smooth na ulit yung andar then after 3 days when i start the engine same problem occurs..
- May 2011
- 481
February 26th, 2012 08:37 PM #4have your fuel system pressure and volume delivery checked. your symptoms seem to be a result of low voltage output from the ignition coil. under load, the spark is barely enough to ignite the air fuel mixture. the available voltage from the ignition coil must be at least 30000 volts to have a satisfactory performance.
- May 2011
- 481
February 26th, 2012 08:41 PM #5have your fuel system pressure and volume delivery checked. your symptoms seem to be a result of low voltage output from the ignition coil. under load, the spark is barely enough to ignite the air fuel mixture. the available voltage from the ignition coil must be at least 30000 volts to have a satisfactory performance. testing the fuel system and the ignition system will most likely to determine what is causing the symptom
Latest mileage:
