Results 1 to 18 of 18
    Patulong ulit sa problema. Car is 2002 or 2003 Lynx Ghia A/T. Car's mileage is 55K na. My tita noticed that when braking and the car goes to a full stop the RPM goes down to 650 to 700 for about 1 to 2 seconds , yung parang mamamatay yun makina, then tataas ulit to 750 to 800. Di pa naman daw sya namatayan ng makina. Ano kaya problem ng tsikot?
    Salamat!
    Mar 2007
    my city is also experiencing the same problem. it drops to about 200 -300 rpm almost stalling the engine. mine is CVT. pupunta nga ako sa casa eh para mapa check ano problema. noon naman hindi ganito ang city ko. baka kailangan din ng calibration yang kotse mo. ewan ko lang ha kasi sa akin need daw i calibrate eh ayon sa manual
    Aug 2004
    Try cleaning the MAF sensor, and have the IACV checked. it could be any number of things related to the intake system and sensors on the Lynx.
    have the same thing going on in my ek. ano kaya prob niya? nalinis ko na iyong iacv and throttle body recently
    Apr 2006
    same with my ek. when i step on the brakes, medyo bumababa ng konti yung rpm. pero konti lang mga 100-200rpm down. parang pag nag-on ako ng headlights, medyo bumababa rin pero konti lang. i guess medyo normal since this is an added load?
    Aug 2004
    Also try checking your ATF level
    pre, paturo naman kung saan at ano yung MAF Sensor, IACV, at ATF Level?
    Nov 2007
    ganyan din corolla ko advice ko lang baka sa aircon may conflict kasi saken pag patay ang aircon hindi naman nagkaka ganun, pero pag buhay ang aircon namamatay na ang makina jump start ko na alng ulit sa 3rd gear,, im sure naman na malalakas ang aircon ng car nyom, kaya para saken sa compresor or sa aircon yan
    Aug 2004
    Quote Originally Posted by prinsipe View Post
    Don't know much about the Lynx but on my Lancer:
    MAF - behind air box. Has a cable plugged into it.
    IACV - on the intake manifold usually at the end of the air intake tube below the throttle body.
    ATF - automatic transmission fluid level. I don't know if your tranny has a dipstick that allows you to check your ATF.
    Niky might be able to help you out more since he drives a Lynx
    Quote Originally Posted by wewoy_romero View Post
    probably Throttle position sensor? or any part that controls fuel by electricity. when voltage drops, so is the TPS and others....
    Dec 2007
    ok din ang suggestions ng mga tropa dito, and also before doin anything else.. check mo muna ang Throttle Body baka madumi lang.
    aite, peace.
    Jul 2006
    Hi... I've experienced the same problem...very similar. Nung dinala ko sa trusted mechanic ko sabi is marumi lang yung IACV or servo raw...so I had it cleaned. Ok naman sya nung una pero after 1 day bumalik ulit sa dati... So ang ginawa ko is dinala ko mismo sa honda casa at pina cleaning ko ulit pati yung throttle body... pero same parin. So I have no choice but to replace the IACV... That solved the problem. It cost me 7,500 for the IACV and 300 for the labor.
    Nov 2003
    clean the iacv, tb and maf and it should be ok na after.
    what's a MAF? where is it located? and how does one clean it DIY style?
    Oct 2007
    Same here. I recently had a tune up because of this problem. They saw that my spark plugs needed replacement, throttle body cleaned, tappets adjusted, intake manifold cleaned. They did all that but then why is it that my RPM drops to 400-500 when I hit the brakes plus when I turn the steering wheel while on a stop. Is this normal?
    Jan 2008
    for the RPM to go down while braking should be normal... but not to the extent na mamatay yung engine... one possible cause for that is syempre medyo luma na din yung vehicle and at the same time your brakes are equipped with "VACUUM BOOST" or HYDRO VAC brake system where the brakes are powered by the vacuum coming from the vehicle.. This is a cylinder attached to the brake system. It has inside a diapragm that when you step on the brakes, a valve open sucking all air inside, the diapragm will help multiply the force you applied on the brake..
    some engines are equipped with vacuum pumps connected to the rear of the alternator.. this pump provides the vacuum for the brake.. but some vehicles gets their vacuum source from the engine it self, they use the vacuum created by engine cylinder while running... so when you step on the brake a vacuum will be created by the engine will be consumed, thus the engine stuggles for this vacuum to be constant to provide power in your brakes...
    try pumping/bombahin (fast and consecutive pumps) your brakes and you will notice the the engine will will struggle, sometimes it will stall caused by the air created by vacuum boost..
    so the rpm going doing to 650 to 700 rpm i think its normal... but lower than 500rpm should be a concern since it may cause the engine to stall.. if the engine stalls while you are running/braking, you will loose steering power, power brakes to control the vehicle..
    also turning the steering will will cause some drop in the engine rpm since your steering pump is creating pressure for you to be able to turn the steering. this will be a burden to the engine affecting the rpm..
    hope this helps
    Same problem i have, just clean IACV, Map Sensor and Trottle Body, ok na yan as long as hndi kna ma-mamatayan ng Makina pero kung medyo may slight na bumababa pa rin -100 RPM from Normal ok lang yun kc luma na talaga ung IACV mo compare sa bago na mabilis ung function. Pag namamatay ung Makina talagang hndi na nag-fufunction yun IACV for that case.
    Kung may extra Big buck ka bili kna ng bago na IACV if you really want the good as brand new ulit syempre. Pero cleaning lang yan im sure ok na yan.
    Jan 2008
    OT:
    1. saan banda makikita ang IACV ng 4AFE?
    2. ang pagbaba ng RPM while braking is sa AT lang ba?
RPM goes down to 650 to 700 while Braking
