Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Hello,
    Hingi lang ako comments on using semi-synthetic oils on diesel engines. I currently use regular oil on my diesel ride pero parang gusto ko i-try yung semi-synthetic. Semi-synthetic lang kasi I find the fully-synthetic oils too expensive e. Also, even if I decide to change to semi-synthetic oil I still would want to change it regularly at 5K intervals.
    Lastly, I have read somewhere that when you switch to synthetic oil you will not be able to go back to using regular oil? Is this true?
    Thanks!
    Dec 2002
    Most semi-synth oils use a mineral base oil plus synthetic additives so the advantages of synthetic oils is not really realized. If you're changing every 5k km, then just stick to a good mineral oil.
    Haven't seen any problem switching from synth to mineral again- i've done it.
    Feb 2005
    meaning not really advisable to shift to semi-synthetic..... rather mineral oil na lang * 5k maintenance..... all the while i thought this semi-syn is better than mineral.....
    Semi-synth is better than mineral in a lot of aspects. But if you regularly change your oil every 5,000 kms then it's not really worth the added expense.
    Feb 2005
    Quote Originally Posted by OTEP
    sir.... have you heard of the brand "per'tua" na semi-syn daw..... coz they're selling at P150/ltr compared to castrol gtx for diesel.... would it be worth a try? salamat po! :question:
    Per'tua is an additive. NO, I would not buy it. Nor would I pour one in my engine if they gave it to me for free.
    Feb 2005
    otep..... thanks! thou there is this new packaging that says "semi-synthetic engine oil" daw and not an additive...
    Aug 2003
    bakit lumalabas nanaman tong PERTUA OIL ads dito sa pampanga...
    its not the additive but its a SEMI SYNTHETIC OIL
    more info --> http://www.pertua.com/products.asp
    for the diesel engines they have the 20w-50 & 15w-40
    here is the info for the diesel engine...
    PER'TUA EXELLO SUPERIOR MOTOR OIL
    (For diesel engines)
    The best lubricant formulated with a patented oil and metal treatment technology that provides the engine excellent shield against wear caused by friction, heat, corrosion, abrasion and impact, and at the same time boosting performance efficiency. Being an anti-oxidant, its chemical stability and normal physical properties parameters are constantly maintained and lasts three to four times longer than the normal life of leading motor oils in the market.
    Keeps engine parts highly protected even at the extreme conditions because of its high viscosity index or highest working temperature.
    Meets Isuzu, Hino, Fuso, Mitsubishi, Toyota, Honda, Mercedes Benz and Volkswagen API passenger car requirements. Exceeds the highest service category of Cl-4 to sustain engine durability where exhaust gas recirculation (EGR) is used and are for use with diesel fuels ranging sulfur content up to 0-5% weight. It can be used in place of CD, CE, CF-4, CG-4 and CH-4 oils. Exceeds performance requirements of Mack, Cummins, Navistar, Detroit, GM 6094M, Ford ESN-M2C121E, ESE-M2C153G and F.
    Grades available:
    20w-50 & 15w-40
    Packaging
    Packaging of Per*tua Exello Superior Motor Oil is, as follows:
    1 liter bottle packed in cases of 24 bottles
    4 liter plastic container
    1 drum of 200 liters
    [SIZE=3]
    anyone tried this?
    [/SIZE]
    mmmm mmukhang ok subukan ah
    May 2005
    Ginagamit namin yang Per'Tua semi-synth oil sa Liteace namin, wala naman kaming naging problema. Although gas yun.
    sir ang petron hauler na oil po ba ok? is regular, semi-syn or synthetic oil?
    Dec 2003
    im using the cheapest petron revx oil, every oil change 550 lang gastos ko including the filter.
    why spend good money pag pwede na yung 550 for a oil change?
    Aug 2003
    Quote Originally Posted by pixelparadigm
    hmmm...
    525pesos kasi yung sa diesel 1 gallon
    tapos 125 per liter daw
    di ko natanong yung sa gasoline
    Sir, di naman madaling mag itim after 5,000 km oil change sa lite ace?
    tnx...
    Sir Mojo: ang mura naman ng oil change mo...including oil filter na
    yung sa crosswind ko filter palang 220petot na VIC oil filter...
    magkano sir petron revx oil per liter mo?
    tnx
    Sep 2004
    Quote Originally Posted by jvdejesus05
    ok na yan sir but we usually use it for our trucks. Though yung trekker ata ang semi synthetic oil ng Petron.
    Jul 2004
    I've been using Delo Sports (Caltex Diesel Semi-synthetic) for the last 2 5K km oil changes and haven't recognize any considerable change on my engine behavior. Maybe I'm not that sensistive.
    saan pala nabibili yung semi synth ng pertua?
    Feb 2005
    I tried using Per'tua semi-synthetic on my newly overhauled engine. Available yan sa MCR/Rudson along Banawe.
    I am using Castrol Magnatec as recommended by Car City for our Starex. Cost me 2250 including orig filter.
    * SAE 10W-40
    * API SM/CF
    * ACEA A3/B3
    Quote Originally Posted by wax
    thanks! try konga makadaan pag mag change oil na ako
    mmmm sayang may mobil1 ako dito fully synthetic, sayang lang kasi gamitin sa diesel
    Aug 2003
    sa pampanga mayroon sa may intersection going to AUF hospital
    chrissan auto supply ata yon...malapit sa EMC tire supply
    135 per liter
    525 per gallon
    that is for the pertua exello semi synthetic oil 15w 40
Semi-synthetic oils on diesel engines
