Forums
Discussions
Events
Community
May 29th, 2004 03:03 PM
Hello, my car dies everytime you hit the brakes hard or sudden stops. What could be causing it?
BTW, it has an automatic trans and drum brakes on all fours. Carb powered.
Thank you very much.
May 29th, 2004 06:29 PM
pero kapag hindi naman biglaan ang pag-preno hindi namamatay?
May 29th, 2004 11:47 PM
1. Does this happen only during warm-up (wala pa sa normal operating temp yung engine, pero pag normal na temp ok na)?
2. When did your car started acting this way? after Change oil/tune-up, change coolant, repairs etc.?
May 30th, 2004 11:17 AM
pa chek mo ung vacuum valve from intake manifold me hose un going to brake booster or hydrovac.
May 30th, 2004 06:51 PM
I got it solved already. My carb has a low float level. I adjusted it up. More than 1/16 of the standard level. While at it, I changed the fuel filters. There are the two: one before the fuel pump and another before the carb.
She runs fine again.
May 30th, 2004 09:39 PM
it feels good to have a perfectly running car.. what's your car?? from you're handle, i'd guess a beetle??
