Results 3,831 to 3,840 of 3899
December 12th, 2018 11:52 AM #3831
- Mar 2010
- 2
January 15th, 2019 04:50 AM #3832good day! can someone kindly confirm that using this oil / oil filter combo, Mobil Delvac MX 15W40 and Baldwin B113 can be used up to 10,000 kms as OCI? Thanks. Also, is Donaldson a good fuel filter? my engine is Isuzu 4JH1-TC.
Thanks!
- May 2017
- 2,128
February 3rd, 2019 06:31 AM #3834
- Feb 2008
- 903
February 3rd, 2019 04:42 PM #3835What is the Baldwin oil filter for Fortuner 2016 Diesel? What about for Innova 2008 gas? Pareho lang ba?
- Nov 2009
- 3,507
February 3rd, 2019 05:19 PM #3836^ 1KD/2KD, 1GD/2GD, 2TR engines use the tiny BT233. You may want to cross-ref OE PN#s at Baldwin site just to be sure.
- Feb 2008
- 903
February 4th, 2019 07:20 AM #3837
- Nov 2009
- 3,507
February 4th, 2019 08:23 AM #3838Erratum to my previous, should be BT223.
Yes you may as long as the thread,gaskets are the same and it fits in the engine, and bypass valve is within specs. Basic principle is the bigger the better because of larger filtering media surface area, filtration is a straightforward/exact science.
- Feb 2008
- 903
February 4th, 2019 04:07 PM #3839Toyota 90915-YZZD2
Baldwin BT223
Donaldson P550335
Baldwin B243^
Donaldson P550400^
Baldwin B1405
Baldwin B178^
Donaldson P554770^
^ long version
Got the above from my back reads here. How would I be able to verify if the above reference number would fit or be equivalent to toyota oil filter for fortuner?
- Nov 2009
- 3,507
February 4th, 2019 04:19 PM #3840BT223 or similar-sized should fit without problems, but if you will upgrade- buy some samples or measure the actual vertical clearance to determine if it will fit in the engine without hitting any hose/accessories.
Sometimes the thread of the spin-on adapter has stand-pipe that you need more clearance for the ing/egress of the filter. Or the diameter won't fit because the spin-on adapter has a lip or the oil cooler does not allow you to go bigger than the OEM. Try backreading more for 2KD who upgraded to bigger filters.
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
