Willing din akong magbigay ng slot! Meron pa naman kasi akong isa pang bd28...kahit isa lang sakin, okay na...Para dumami makatry...
May tumawag na ba sa Volmax?
Try ko sir...Wala kasi akong access sa landline...post ko dito pag nakatawag ako...Thanks!
just called. still no stock of BD28. price is 765. a month or 2 pa raw magkaka-stock
tuloy pa ba ang group buy? update ko order ko 4 pcs nalang sino pwede bumili pay konalang since im a looong way from manila![]()
hahaha ang tagal pa... 300kms nalang dad ko bago magchange oil.. baka mag oem muna kami:D
Ang mahal pala ng K&N oil filter. It cost Php1,300. For those who wanted to buy purolator oil filter, authorized distributor ung Big O's Tire Corporation. They have this ACDelco battery booth and I saw their purolator too. Mas cheaper than VIC.
I often see the Repsol Brand Mineral based oil as advertised. Okay ba ang quality nito? how does it fare against Castrol GTX for diesel engine?
dvldoc, changed my oil filter to fleetguard LF3564, noticed that the oil indicator on the dash goes off faster than when using Baldwin BD28. Actually this is more the same as the OEM oil filter. what could be the reason for this?
Doc, Folks,
I'm planning to have this oil drain on my gasoline engine running for 1 week now (06 honda jazz 1.5) not sure of this oil, if safe or not, becuase its not API, SL, ETC... approved. please advise thank you!
Mobil 1 ESP Formula M 5W-40 is approved against Daimler Chrysler MB 229.51.
I am not familiar with them. But here's the MSDS of them.
Lubricants
Lubricants
Their diesel oils meet cummins standards so that's a good thing.
Ideal for gas cars with cats. Has high VI so its good for gas engines IMO. Mobil 1 ESP Formula M 5W-40 - Emission System Protection
Fasten your seatbelt! Or else...Driven To Thrill!
guys, I-unload ko lang oils ko dito sa bahay... hindi ko na kasi maasikaso yung langis eh ,,, vey busy with other things...
kahit luge, para lang hindi nakatambak....
*mobil delvac 15w40 (180per liter) 200 plus sa labas yan
*zic UP 10w40 (200 per liter) 220 plus yan sa labas
*Bardahl synpulsar-m 5w-40 (fully synthetic) (370 per liter) 390 plus sa sulit...
Looks like perfectly fine oil, a little low in the ZDDP but good moly and boron to make up for that. And at almost 15000kl
on this sample still has enough TBN to go a few thousand more.
But if you have car with sluge issues this would be a bad oil for you since the detergents are so low (calcium) is way below the normal average.
dvldoc, speaking of sludge, is it safe to assume that sludge is from use of low quality oil + low quality filter?
