Originally Posted by
alwayz_yummy
sagot ako dito:
1. alternator itself di madali masira, kalimitan yung regulator lang nasisira. most modern alternator have IC regulators built in to them but eto share ko: if you tap a VOM (volt-OHM meter)--importante meron kang ganito, kahit papaano mamomonitor mo. but having a analog/digital volt meter and ammeter will help also..
dapat kung di buhay makina, dapat reading nyan is atleast 11.5V to start the engine. tapos pag tumakbo na yung makina dapat magmaintain yan from 12.1-14.5V, other wise, may problem na regulator mo. dapat * full load(all electricals ar up/on, dapat 12.1 yan para di madiscarga baterya mo. if bumaba sa 12V, while the engine is running and * full load, may alternator problem ka na..either kailangan palitan ng windings yun kasi sunog na masyado ang windings...
kung lumalagpas ng 14.5V * no load, then regulator mo problem..pagawa mo yan, delicado yan kasi susunugin nyan linya mo, papakuluin ang batterya mo kasi sa lakas ng kuryenteng pumapasok sa baterya (over current). 2 solusyon yun, kung dadalhin mo sa alternator shop, pwede papalitan mo yung IC nu and/diodes nun kasi sira na..
but if ok ang karga ng alternator, at nadidischarge parin ang battery, baka baterya mo na ang problema..punta ka sa battery shop may pantest sila dun..
and if EFI/CRDi makina mo, as much as possible iwasan mo mag-jumpstart kasi baka masira ECU,e.. although di madali masira yun, but better safe than sorry ha..
2. check your electrical charging system. lights are good indicator ng charging efficiency ng sasakyan mo, unless LED gamit mo..LED di madali nagbabago ang brightness..
3.baka may maluwag lang... since pinalitan to 4age yan, most likely may nilagay sa ilalim ng dash..
4. baka may maluwag lang.. check mo yung actuator baka may konting sagabal lalo na pag na-vivibrate..
