Results 1 to 20 of 20
    Jun 2004
    hello mga gurus,
    i have a nissan sentra gx 2007 model, whose engine wont start. at first i thought it was the battery but i noticed that all my lights were still strong and my horn still loud. i just had my 50k pms from casa. aside from the battery what else could cause this problem? considering that my car is fairly new what else should i consider?
    hoping for your expert advice. thanks.
    Jun 2004
    i bought my battery march 2010.
    do you mean starter not cranking?
    Quote Originally Posted by attic_dude View Post
    hello mga gurus,
    More info needed.
    Does the engine crank over? When it cranks, does it sputter or just cranking over and over?
    Jun 2004
    sorry for the late update. i had my car towed and brought to casa. it wont crank at all. when i put the key to on, i can hear the whirring sound (like electronic) sound after which i am supposed to turn the key and the engine comes to life. but after the whirring sound, nothing happens, just a "click" sound. i got a new battery and still the same thing.
    could this be due to engine failure? or the starter? any help would be greatly appreciated.
    thanks in advance.
    Jun 2004
    my car is m/t.
    thanks in advance.
    Sounds like a starter problem. The solenoid motor which pushes the actual starter motor gear into the flywheel might have a problem (failed for some reason).
    Jun 2004
    thanks sa feedback ghosthunter. i'll call my service advisor.
    Jun 2004
    its 4 pm still no word from casa, i hope di aabot ng sabado to.
    No word from the SA, even a problem diagnosis?
    Jun 2004
    actually i was wondering if they would immediately use a diagnostic tool for this kind of problem. i wish they would. cant seem to reach him, no one's picking up on the other end. oh well looks like kelangan overnight yung oto ko
    Nope, if the starter itself has a physical problem, you cannot detect it using the plug-in electronic diagnostics tool.
    Jun 2004
    naka tawag na ako sa SA. sabi di daw kaya today. nag diagnostics sila. wala daw problema sa sensors or sa engine. so electronics daw. try daw nila yung alarm ko baka yun daw yun. kaso sa tingin ko, wala naman problema yung alarm ko. nakaka pag arm disarm naman siya. any thoughts?
    most likely a starter or wiring problem. m/t doesn't have electronic inhibitor switch except for the clutch pedal switch. i wonder why it took them so long to diagnose the problem; 5 to 10 min is enough to diagnose a starter problem (if indeed its the problem).
    Quote Originally Posted by t2erns View Post
    Exactly my thought.
    Jun 2004
    it might be because they had a full schedule when i arrived. hence i wasnt priority. they said to call at 130 pm. ill let you guys know.
    Jun 2004
    wow they told me exactly what you guys posted (starter) and it took them 1 and a half days to do it. di pa nila nababa they told me to call back 330. theyre not even sure if i can get it today. so frustrating.
    now it will take them another 2 hrs to take down the starter.'wonder how they'll charge the r & r, actual time? maybe.. he he
    Jun 2004
    they finally finished the repair at around 5 pm. the starter was covered in carbon deposits thats why it wasnt working. the whole cleaning cost plus labor cost me 2.8k, ouch!! they said the starter should be checked every 3 yrs, i thought that was supposed to be standard in certain pms check ups. oh well at least its working now. thanks to everyone who replied to my thread
    May 2009
    WHATTA!!!!P2.8k for a starter cleaning job only?...anyway, its casa. no doubt. pero teka lang, cleaning lang ginawa? baka pati palit carbon brush?...more than an arm and a leg naman kung cleaning lang...
    my case is another issue since i DIYed replacing the carbon brush since i had a high wattage soldering iron and lotsa solder. carbon brush cost me P180 for 4 pcs (just the local brands)....
qg13de engine wont start
