Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
    Dec 2020
    #21
    my guess is,
    your engine is so worn, oil is getting into the combustion chamber and is being burned along with the fuel.
    this results in dark smoke and oil loss.
    ... worn valve stems, guides and seals... worn piston rings... a hit in the cylinder wall!
    baka complete engine overhaul na ang kailangan, bai.
    Sir yung pistons, piston rings and valve seals bago lahat. And besides, sabi ng mekaniko okay pa naman daw ang cylinders. Pati mga spark plugs pinapalitan na ng bago. Baka naman kako may pagkakamali ang mekaniko sa pagkakabit. Sa palagay mo sir? Pasensya na ha. noob pa kasi ako sa ganyan.
    #22
    Quote Originally Posted by rvchicz View Post
    obviously, you're leaking oil somewhere, causing your engine to burn it in the combustion chamber.
    good luck in your investigation.
    Jun 2005
    #23
    Tapos yun pala barado lang ang PCV.
    He he he
    Sent from my MI MAX 2 using Tapatalk
    #24
    Quote Originally Posted by sirkosero View Post
    He he he
    kung puede lang sana...
    Dec 2020
    #25
    Salamat sa mga sagot sir. At sa lahat na nagcomment salamat sa inyo. Siguro nga ipageneral overhaul ko na lang.
    Dec 2009
    #26
    ^get that 2nd opinion from another mechanic
    Pumapasa naman ba sa emission test ang sasakyan mo?
    Sent from my SM-G532G using Tapatalk
Q: Bakit nagiging mausok, mahina hatak at magastos sa gasoline/diesel ang sasakyan?
