Results 11 to 20 of 26
- Dec 2020
- 13
December 3rd, 2020 12:44 PM #11Magandang araw sir. Hindi ko alam kung nasa tamang forum ako. Makikitanong lang sir. Nag-usok ang sasakyan ko dati, (Suzuki multi van f6A engine) sabi ng mekaniko bali daw ang piston ring. So pinapalitan na ng set of pistons/piston rings, valve seals and gaskets pero after magawa mausok pa din. Sabi 1 week daw mawawala ang usok pero ang nakakapagtaka, almost two weeks na, sobrang lakas pa din ng usok. At nababawasan ang langis niya. Malakas naman humatak, hindi nababawasan ang tubig sa radiator and reservoir, very smooth ang andar. Usok lang ang problema. Ano po kayang problema nito sir? Nawala na kasi yung mekaniko na gumawa e. Thanks.
December 3rd, 2020 01:37 PM #12
after the piston ring replacement? nag "break-in" ka ba ng maayos? (as in hinay hinay driving?)
2nd, gaano kalakas magbawas ng langis?
December 3rd, 2020 03:43 PM #13
- Jan 2008
- 4,726
December 3rd, 2020 07:12 PM #14
December 3rd, 2020 09:32 PM #15
sa totoo lang, oakiramdam ko dunikot lang yung piston para palitan yung Piston Ring.
Baka may tama na yung cylinder kaso para mababa yung gastos, sinubukan nung mechanic na piston ring muna.
- 52,513
December 3rd, 2020 10:37 PM #16my guess is,
your engine is so worn, oil is getting into the combustion chamber and is being burned along with the fuel.
this results in dark smoke and oil loss.
... worn valve stems, guides and seals... worn piston rings... a hit in the cylinder wall!
baka complete engine overhaul na ang kailangan, bai.
- Dec 2020
- 13
December 4th, 2020 09:21 PM #17
- Dec 2020
- 13
December 4th, 2020 09:24 PM #18
- Dec 2020
- 13
December 4th, 2020 09:27 PM #19
- Dec 2020
- 13
December 4th, 2020 09:32 PM #20
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
