Results 31 to 40 of 41
- Aug 2006
- 337
August 16th, 2006 10:57 AM #31
- Jun 2006
- 18
August 16th, 2006 01:02 PM #32cams, higher compression pistons, and polished and ported heads ... so sir.. do you know of any shops that could do this? even if i still want the invecs.. can the a/t hack the extra power? also.. stock engine is also sohc.. can i replace it with a dohc ?
August 16th, 2006 03:35 PM #33
ATI in Cavite. It's on the way up to Tagaytay from Santa Rosa.
They do port and polish jobs to varying degrees, and they have a flow bench to test their work with. They do overbores, high-comp piston swaps, frankensteins, etcetera. My clubmate had his RS overhauled there, the port&polish and flywheel lightening (can't do the flywheel on an AT, sorry) cost only 20+ k. That's not including the overhaul fee, mind you.
A DOHC swap may be complicated. You have to make sure your engine has the same bore and stroke as the DOHC engine you're getting your head from, and you'll have to transplant the ECU, too. Sorry, don't know much about 4Gs.
If you want to maximize power from a turbo, you might want to look at swapping out for a manual tranny (don't know about wiring issues with the INVECS, as far as I know, it's a seperate ECU)... or getting a high-stall torque converter, that locks up at a higher RPM than the stock torque converter (like 4000rpm, for example, instead of 2500...), but then, that route is for more acceleration, not tranny life. Safest route, get a transmission cooler and switch to a more stable ATF fluid.
August 16th, 2006 09:33 PM #34
- Oct 2005
- 147
August 16th, 2006 10:22 PM #36
with exception sa LTO main--diliman,
madali lang naman na process yan, 500 lang ata..basta kumpleto ka ng documents:resibo,or/cr, ok na yan.... 1/2-1 day affair lang yan.
August 16th, 2006 10:24 PM #37
eto requirements:
Change Chassis/Engine/Body/Body Design
Documents Required For Private Vehicles
1. Original Certificate of Registration (CR) and latest original Official Receipt (OR) of payment
2. Original copy of Sales Invoice of Chassis / Engine / Body
3. Affidavit of Change of Chassis / Engine / Body / Body Design
4. Clearance from Philippine National Police-Traffic Management Group (PNP-TMG)
5. Endorsement from the Insurance Company
6. Actual inspection of MV with duly accomplished MVIR [Download this form here]
7. Confirmation of Dealer's Report from Registration Section / Regional Office
8. Taxpayer's Identification Number (TIN)Last edited by ssaloon; August 16th, 2006 at 10:33 PM.
August 16th, 2006 10:29 PM #38
- Oct 2005
- 147
August 17th, 2006 08:46 AM #39paesnsiya. na hi-jack ko yata yung thread...
ok lang ba isabay sa change owner ship yung change engine?
or i-file ko muna yung change owner then change engine?
August 17th, 2006 09:46 AM #40
magulo pag ganun..change ownrer muna, then change engine...
pwede lang pagsabayin na walang hassle is change owner ang renew ng rehistro...
109,606 vehicles were sold in the first quarter of 2024 | TopGear PH
Car Sales Data (2024)
