Results 11 to 20 of 27
May 7th, 2007 01:11 AM #11
replacing the tank may prove to be more practical if the price of a tank is cheaper than having it welded...you will need to ask for warranty if you purchase one...you will need to have the new tank tested for gas leak first before installing it on the car, to avoid dismantling it if there's to be a leak later on...
- Jul 2005
- 122
May 10th, 2007 06:31 PM #12nag-canvass ako ng surplus na gas tank sa banawe. average price is 4.5K. mas mura yung estimate sakin kung ipa-hinang nalang with bronze. so ayun they pulled down the tank, drained and washed it. tapos hininang and nilagyan pa ng patch na bronze or tanso din. I only paid 1K... also by draining the tank, nalinis na din at the same time bec madami na din palang mga latak... solved na po ang fuel leak sa sasakyan ko. now I can consider this issue closed.
MARAMING SALAMAT SA INYONG LAHAT!!!
- Jun 2007
- 6
June 8th, 2007 03:48 PM #13I'm having the same problems right now. Can you tell me where you got it fixed?
July 26th, 2007 04:31 PM #14
same problem with mine. may leak na yung gas tank. nalaman ko nalang nun nagpafull tank ako. nasayang tuloy ang gas. tsk tsk
taga mandaluyong din ako, san kaya magaling magpaayos nito???
attention duncan_sheek!!!
thanks.
- Sep 2007
- 207
November 25th, 2007 04:45 PM #15got the same problem... napagawa ko na yung dalawang butas sa ibabaw ng tank ko. pero after a month kumatas ulit.. saan kaya makakabili ng fuel tank and mga magkano for a lancer 95'?
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 25th, 2007 05:37 PM #16should be pretty easy to get one pero be sure to specify whether it is for a injected or carburated engine since iba sila.
- Sep 2007
- 207
- Feb 2005
- 51
- Nov 2003
- 3,849
- Aug 2008
- 11
September 2nd, 2008 12:59 AM #20Same problem. Ser Duncan (or anybody), san ka nagpagawa? My unit is a 95 corolla gli. Malapit ako sa pasig, san kaya dun pede magpaayos ng tank? tnx!
Looks like TGPH silently edited the article and removed the entry for Velocita Motors/Ferrari.
Car Sales Data (2024)
