Originally Posted by
ghosthunter
But one concern if you don't use the car that often is the gasoline. E10 gasoline can spoil in the fuel tank if it is not used within 3 or 4 weeks. This results in poor performance or even a rough running engine. At worst, the engine will not even start.
You can avoid this problem by either using gasoline without E10 or only have a small amount of E10 gasoline in your tank so it is used up in less than 3 or 4 weeks.
