Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
    Aug 2003
    #21
    in my case, ung fuel filter ang me sala. medyo circumstantial, but i think it was what caused the nasty backfire that it fried a portion of the air filter element:
    after replacing with an original, umOK kaagad.
    my suking shop recommends another replacement brand; he said wala naman daw problema. i'll be keeping the original filter at hand just in case.
    #22
    Hingi rin ako advice sa regarding sa similar na problem ng mahina kong EFI , sinisinok din esp pag na 4th to 5th gear ako esp pag pataas na road.pero pag menor ako at nag acelerate ulit medyo nawawala pero bumabalik, Nag palit na ko ng 4 na bosch spark plug at fuel filter .
    sabi ng mechaniko mag change ako to 95 octane baka maging smooth takbo, I tried the V power unleaded ng shell pero nothing change. sabi pa ng mechanic ko wala na raw siya makita na problem , yun lang daw yun..
    ..Thanks
    Nov 2003
    #23
    sometimes nasa pagmamaneho rin. if you shift too early the engine has a hard time coz wala sya power.
parang sinisinok ang makina...
