Results 21 to 30 of 34
May 16th, 2007 08:55 AM #21
binili ko ung engine sa surplus dealer then iniuwi ko sa bahay where i contracted a mechanic and an electrician to work on it. when installation was completed, we ran the engine and it ran smoothly, it looks like okey yong d15 engine na napili ng mekaniko ko. we had the timing belt change during the installation of the engine.
its the same Esi old computer box we used, however we observed the Vtec works a little bit late, further acceleration needed than normal to get the Vtec working, i can only conclude when buying d15 it must come complete with computer box i'm not quiet sure it's only my observation.
May 16th, 2007 03:12 PM #23
nice. swerte mo ganda pa engine nakuha mo. pero diba usualy sa 25k kasama na computer box?.dami ko na kase narinig horor stories sa makina na nakuha nila e.k20 yay mejo madugo pa un. b16 hindi kaya budget malamang mas mahal k20.anyway habol ko talaga ung pang daily driving tipid saka may descente na billis kung sa open road.sa tingin ko d15 vtec ung kelangan ko.la talaga makuha sa ph12 e.actualy kahit ph16 baka pwede na e. pero d15 na lang talaga.mukha ganda balance ng perf ng engine na un e.inluv lang talaga ko sa eg hatch kaya di ko mabitawan e.
May 17th, 2007 04:59 PM #24
gowthead, you're right the d15 came complete with a computer box, i discovered it wasn't fitted for the new engine instead the electrician decided to make do with the old ph16 computer box. supervision on my part ang kulang, when i confronted the electrician, he claimed the ph16 computer box will do just fine. well and good, during test drives, i felt the d15 is an overkill for a light sedan car like esi, it has tremendous reserved power, walang tope. you'd feel like the weight of the car is so light for an engine like d15 and as a result, improved fuel economy, better than ph16. I suggest d15 para sa hatchback mo bro.
May 19th, 2007 04:07 PM #25
ideal nga talaga sana .. kaso kulang pa funds ko ngaun. inuna ko ung body repair (bubong) mejo grabe na kase e. balak ko nga mag loan kahit 50thou. i think that should suffice. pero even if i had the money bigger problem is to get a engine that is in good condition. may prospect na ko either kanzai or drop it. kase from what ive read aside from installing the engine they can also tune it afterwards or check sa mga deperencia o kelangan palitan. sa evang kse naka panood na ko ng instalation sa initial D. kaso lang engine and instalation lang sagot nila you would have to drive the car somewhere else sa tuning o change oil.
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 20th, 2007 11:05 AM #26it's impossible for your mechanic to have gotten vtec to work on the stock esi box. it's not vtec you are feeling.
May 22nd, 2007 06:18 AM #28
- Nov 2003
- 3,849
September 17th, 2007 12:07 AM #30
pasingit lang, speedyfix, if you dont mind po, ask ko lang magkano palit engine sa inyo, balak ko palitan yung sa Mitsu Galant SS 96 Matic ko. MAy nag-advice sakin na ipalit ko daw ay yung 4g93DOHC 1.8L DOHC non-turbo or 4g93MIVTEC/T (1.8L MIVEC or turbo) or 4g63 DOHC. match po ba yun sa kotse ko? Mga magkano po magagastos kung sa inyo ako papagawa? Gusto ko kasi sa Speedyfix pra sigurado. thanks!
