Results 11 to 17 of 17
- Dec 2007
- 11
December 24th, 2007 07:02 PM #11
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Dec 2007
- 11
December 30th, 2007 10:54 PM #13mga bro konting update sa problem ko,
ndi kaya sa injectors na ko me problem, or could it possibly on my ecu???
ganito kc, 1 2 3 4 injectors, minsan nawalan ng supply ang #1, so para malaman kung sira talaga, swap ko ung #1 to #2, ok naman sya, tapos nagkaron ng supply ung #1 ulit. pero palyado pa rin eventhough working na ulit ung 4 injectors. then this day, i drove 5km then napansin ko even naka idle lang palyado na talaga, its like 3 pistons are working, un bang when you pulled 1 of the tension wires prang ganun.
checked ko ung injector #1 walang respons ang engine nung tinanggal ko ung connector while it's idling, then ung #2 inalis ko rin, me respons pero konti lang, then #3 sobrang respons halos mamatay na engine ko, #4 prang respons lang nung #2, pero ung #1 its like dead.
tapos nung ginamit ko ulit this night, meron respons na ulit ung injector #1. and ung idling ko e normal na ulit, pero palyado pa rin walang hatak.
we also check the connectors for voltage, pag off ang engine there's 12V on each, and 1v pulsating when the engine is running, idle.
what do you think guys?? how can i make sure my injectors are all failing?
December 31st, 2007 02:06 PM #14
since na check mo na fuel system, i think you have to check the air delivery system. check and clean MAF sensor a dirty maf will not give ecu the actual air delivered same as if there's a leak between the maf and the throttle body unmetered air may be entering the system same with vac leaks. recheck your cam timing.
- Nov 2003
- 3,849
January 1st, 2008 12:15 PM #15try replacing the injectors... if not maybe the fuel reg...
the civic uses a map syetem though so no need to check the maf. if the map is misreading it should normally throw a cel.
- Dec 2007
- 11
January 1st, 2008 08:50 PM #16
- Nov 2003
- 3,849
January 6th, 2008 12:34 PM #17you'll have to ask a surplus shop coz wala ako. the fuel reg is on the right side of the fuel rail when you're looking at the engine.
Traffic!
