Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    P1v1/t1 = p2v2/t2 .
    Cooling system is sealed so atmospheric pressure shouldn't be affecting internal pressure.
    But the ambient air itself will be less dense and will have a reduced cooling effect.
    F1 at high altitude tracks more cars overheat (just like Baguio).
    Feb 2024
    Engines also work harder, right?
    Jan 2009
    Not fully sealed.
    The coolant pressure cap keeps the pressure inside the system at a set pressure above atmospheric pressure. So if you lower the atmospheric pressure, the valve will release the excess until it equalizes again to the set cap pressure above atmospheric pressure. Hence, the cooling system will run at a lower pressure at high elevations.
    Agree. The radiator will not be able to shed as much heat due to less air molecules to transfer to.
    As a side note, you will see in many equipment like electronics (ie. servers, IT equipment, some consumer electronics, etc.) wherein the specs may have a stipulation about the maximum altitude the said equipment can be safely operated. It's because of the less dense air at altitude, which can interfere with the equipments' own cooling capabilities.
    Case in point, most projectors has an on-screen setting wherein you can set it to Normal or High-altitude mode. The main difference is, in Normal mode, the fans operate at various speeds and would likely spin at low speed to reduce noise. But once the projector gets hot enough, the fans ramp up to high speed. But in High-altitude mode, the fans are always at high speed to compensate for the thinner air.
    Yeah you're right about the radiator cap being relative to ambient, but IIRC the boiling point elevation you get from a 1 bar radiator cap plus a 50-50 coolant mix is high enough that the change in elevation shouldn't matter.
    Metro manila is currently 1006hPa, Baguio at 853hPa. Boiling point will be just under 100C here, 96C in Baguio -- 4% decrease.
    A 1 bar radiator cap raises boiling point to 268F (130C). Applying the same 4% loss (since the percentage pressure delta will be similar) = 124.8C. I don't think a car will be seeing 120+ coolant temps even in Baguio.
    AFAIK one of the reasons behind pressurized cooling systems is so that modern cars can perform at altitude -- yes the boiling point is lower, but the cooling system is overdesigned and should handle it (provided of course that it's properly maintained).
    Jan 2009
    provided of course that it's properly maintained.
    I think THAT may very well be one of the likely reasons.
    It's quite evident that the cooling system is one of those things that are frequently misunderstood or otherwise taken for granted. Especially so if you live primarily in the lowlands like Metro Manila. With the thicker air, the cooling system is quite tolerant up to a certain extent.
    But going up to Baguio, it may seem that the combination of the high elevation, sustained uphill climbs, slow-moving traffic, and frequent stop and go, contributes to a hotter than usual engine. Also, many A/Ts/CVTs have a shared cooling/heat exchanger integrated into the radiator. The conditions above would undoubtedly increase the ATF/CVTF temperature which is then dissipated into the radiator as additional thermal energy that needs to be shed.
    These conditions combined together makes for an unforgiving cooling system. As such, the coolant type, coolant ratio, coolant level, pressure regulation mechanisms, overall system design, engine health, etc., becomes critical.
    Jul 2013
    Balikan ko itong first post...
    Lately, I've been seeing a number of ads in my Feeds about a certain aftermarket high-CFM auxiliary fan being sold either as an upgrade to the OE aux fans or as a bolt-on to complement vehicles with traditional belt-driven fans. My first reaction was, these fans make a lot of noise and seems overkill.
    Yung mga kilala ko na naka 300cc Vespa na used for their regular commute decided to put an additional aux fan to blow the hot air out. The extra fan is not as strong as the original ones, pero its only used to complement the stock fans.
    Nung may taxi pa kami (90's). Every summer, we diverted the windshield washer to spray water to the radiator.
    Nov 2019
    But then I recalled this video from 2023 about "stalled" cars going to Baguio in bumper-to-bumper traffic (credit to its owner): https://www.facebook.com/share/v/19arRvX9LR/
    Based on the video and despite what the owner is saying, it's not perfectly conclusive whether or not every car shown on the side of the road suffered from overheating.... BUT, it does look like it at face value (hood's up, some people tinkering in the vicinity of the radiator, etc.). Whether that's wholly or partly true, I want to hear your take on it.
    I've always believed that most modern cars are designed to operate in virtually any conditions. My hypothesis however, is that the high elevation, and hence lower air pressure and density, has a lot to do with it. Less air molecules makes the cooling system struggle to shed heat. So maybe those aftermarket aux fans CAN help under these conditions.
    Yung extra AUX Fan is useful sa mga naka montero.
    Mag improve daw yung AC system since may extra compartment daw na lalagyan ng AUX Fan for AC.
    Not sure if this also helps mitigates the overheating or helps compliments the cooling system of the engine.
    Since may independent AUX fan na for AC if pa installan nyo.
    Hindi lang nilagyan ng Mitsubishi para maka tipid.
    Is this true Montero owners?
    Jul 2014
    I received this email from Fleetguard
    Understanding coolant and recommendations
    I think this webinar is not exactly for cars, but I guess, (liquid) cooling systems are similar naman for most types of engines.
    Understanding Coolant and recommendations - Album on Imgur
    Webinar Registration - Zoom
