Results 1 to 6 of 6
    Dec 2008
    Help naman po with my lancer el96. knina muntik na ko mag over heat
    parang may naririning ako sumisingaw bago tumaas ang temperature di namn po ko nag oover heat dati Anu po kaya sira or bumigay na part dun. Tnx po papagawa ko po kc tomorrow.
    Check mo kung gumagana yung fan and aux fan. pag working check for signs o leaks, maraming paang gagalingan nito(radiator,hose fittings watr pump etc. Bring it to a certified mechanic to asses further yung problem.
    Jan 2009
    Quote Originally Posted by S_E_P_H View Post
    usually pg 'my sumingaw' n sound e s cylinder head gling at probablly nag loose compresion n sya kya ng overheat. ptgnan m n s mekaniko, gud luck,,
    Quote Originally Posted by jE_Valdez View Post
    sir text speak/ txt format is prohibited in the forums.
    please read the rules
    Oct 2008
    thermostat check din po... baka matagal na nagbubukas
    Nov 2003
    baka may singaw or butas yung radiator mo. that will probably be the one to make singaw.
overheat
