Results 1 to 10 of 14
- Sep 2010
- 131
January 24th, 2011 10:56 PM #1I just wanna know if an oily spark plug means that i should have it overhauled? i just had it overhauled 4th quarter last year... or should it be considered "back job"? My car is Toyota Corolla 95 Big Body... 3 of the 4 spark plugs are covered with oil... only one is colored rusty brown... the mechanic told me that it was only dirty and no problem at all... i am kinda hesitant about that... oily sparkplug means a problem in piston ring or other parts...
- Jan 2008
- 4,726
January 26th, 2011 12:34 AM #3nasan ba yung oil?? sa tip or sa thread?? kasi kung sa tip eh kumakain na ng langis yang engine mo.. which in time will need an overhaul.. top overhaul siguro ok na..
- Aug 2008
- 38
January 26th, 2011 01:43 PM #4pards,
check mo muna, baka spark plug oil seal lang yan. Patayin mo muna makina, then tangalin mo yung hi-tension wire, kapain mo ngayon yung mga butas na pinagsasaksakan ng wire, dapat tuyo yan, wala kang langis na makakapa. Kung malangis, sigurado na spark plug oil seal yan, 250 yan 4 na piraso na.
Kaya mo ng gawin yan, tangalin mo lang yung cover, then sa likod ng cover, angat mo lang yung lock, matatangal na yan.
Bago mo ibalik linisin mo muna mga butas, make sure na walng maiiwan na basahan. hehehe palit spark plug ka na rin para sigurado ka at ma test mo maige.
sana eto lang sira.
good luck
- Jul 2003
- 573
January 26th, 2011 03:38 PM #5what was done and replaced during the last overhaul? have you verified that the actual overhaul was done right?
January 29th, 2011 02:27 PM #6
is changing the sparkplug seals included when overhauling the engine? and also the timing belt?
imho, if its me i will have to clarify this with the mechanic whose doing the overhauling, including other major parts such as timing belt and water pump et al... to avoid things like this from happening....
January 29th, 2011 02:28 PM #7
- Sep 2010
- 131
January 29th, 2011 06:10 PM #8i really have no idea, i'll try to check it again. the dark substance which i think is oil, covers the whole thread of the spark plugs
January 29th, 2011 06:28 PM #9
if the suspected substance is on the threaded area, chances are, it is anti-seize compound. if the spark plugs were not tightened to their proper torque, it might be oil originating from leaks of the spark plug tube seals. if the tube seals are leaking, the first evidence would be swollen spark plug wire boots. if it comes from the combustion chambers, it will be consuming oil more than normal
- Sep 2010
- 131
February 1st, 2011 08:50 PM #10how do i know if they are in their proper torque? do i need the gadget for that?
I went with him at LTO's The Link satellite office nung nag-renew sya. We were given a number to...
