Results 1 to 17 of 17
    Dec 2007
    I just had my change oil last Christmas break (3 months ago) and when I had my fuel refill, the gasoline boy asked me when my last oil change was. I was surprised to get asked this question and he showed me that the oil was already dark.
    The oil i purchased and used was the best Diesel engine oil Mobil had to offer. The 6L of fully synthetic Mobil 1 cost me around 5k.
    (4d56 engine)
    Ano kaya ang problem?
    imho, tama lang na magdarken agad ang oil. it means that it is working.
    ang nakakatakot, is after three months, slight darkening pa lang nangyayari. it means that the oil is not cleaning your engine.
    Apr 2004
    Quote Originally Posted by 1D4LV View Post
    yep.
    or, parati ka bumibiyahe sa mga mausok at maalikabok na lugar. lakas humgop ng hangin ng diesel... yung nahihigop nga nappunta sa makina yon.
    is this true even for gas engines?
    and besides since diesel pala ang sasakyan mo, pag change oil mo ilan araw lang itim na rin kaagad ang oil mo...
    pereho tayo sa gas engine naman ng 2000 revo glx last dec din na change oil ng tignan ko kahapon maitim na. since meron naman akong stock na mineral oil change oil ko na lang DIY, ganda na uli ang takbo, mura lang naman ang mineral oil wag nang paghinayangan.
    my question naman sa TS is ilang thousand na natakbo ng adventure since dec.? at baka lang di pang diesel mobil mo? Delvac ang FS niyan. kahit fully synthetic pa oil for diesel hindi bagay paabutin ng 10K kms. at considering na old school rin ang 4d56, any multigrade mineral or your choice pa rin ang bagay. kahit oil change mo ng every 4K kms di masakit sa bulsa at mas ramdam mo ang smoothness niya sure yan
    Quote Originally Posted by spyghost View Post
    yes.
    sa akin, one week, maitim na. the only time i had an unchanged oil color for a long time is around three weeks, when i used Castrol GTX.
    pero lahat ng langis na ginamit ko, may changes na after three days.
    i switched to shell blue and i noticed that discoloration only happened after 1.5k. can we say that this oil is not good enough? my engine is 4g15 with 75k mileage. oil filter is vic
    Jun 2008
    you have engine sludge, dont matter your using best motor oil like mobile or Castrol GTX only way to get rid of it is to hot tank the block and head then rebuild it back.
    Apr 2008
    Quote Originally Posted by 4agze View Post
    mahirap kase magsabi sa oil since ang kaya lang natin basehan yung visual (color), viscosity and texture.. from where i work they do some oil analysis pero for big companies na yun
    pero sa totoo lang normal na magdarken ang oil regardless of time ng oil change, unless d mo start ang engine, since madami din deposits ang nasa engine natin.
    i dont see any problem with it. don't worry about it bro, just observe the proper oil change intervals.
    is it advisable to change oil filter halfway between oci's? or is it already unnecessary?
    Nov 2003
    if the oil gets dark that's good. it means it's cleaning the engine. if it doesn't then walang silbi yung oil.
    check for thicksness in the oil, if it gets too thick or smells burnt then it's been there too long na.
    Me, bago ako mag oil-change, I add a can of Shell Flushing Oil, run for 5 mins. at idling, ayun, tanggal dumi.
    is this true... some mechanics pull the dipstick and let the oil drip... if it still drips, good pa daw? myth or true?
    Hello Mga Sir,
    Last January 2009 I had the Corolla A/T '95 oil changed sa Rapide sa Quezon Ave., regular/mineral lang - AC Delco yung ginamit.
    This April 2009 after it ran just about 1.1 kms I checked lang this morning yung Oil, mejo brown na and i don't smell strong odor of burnt oil although i think i smell a little. Is this normal? Ok pa po ba ito eh kasi nabasa ko po sa mga previous posts na maganda pala yung mejo nagdarken yung oil means effective ito. Na-paranoid kasi ako bigla.
    And di ba after 5km interval pa palitan or after 5mos. yata, eh since city driving lang after 4mos. kami kaya 1,000+ kms pa lang ang tinakbo.
    Papaano po kung di pa umabot ng 5k kms ang tinakbo after 6 mos. let's say 2.5k lang. Kailangan na po bang palitan?
    By the way, the next time I change the oil try ko sa Speedyfix, pero regular pa din siguro, is their synthetic purple oil worth it? I will have my brake and radiator fluids serviced sa kanila this week. I've been reading a lot of positive feedbacks here regarding that shop.
    Thank you po in advance sa replies.
    Malaking tulong po kayo.
Oil too dark
