Results 1 to 10 of 10
    Jun 2008
    Nagchange oil kasi this month ako after 3 days lang check ko yun oil itim na agad. Ano kaya problema? common lang ba to kasi old na yun engine 4ja1:old:.
    Jan 2008
    normal po yan sa diesel engines.. even after the change oil procedure, the oil will turn to black again once you start the engine
    normal lang for diesel engines, just follow the oil change schedule religiously para less worries.
    normal lang yan sa diesel, tingnan mo kahit bagong lagay pag nag circulate na itim na agad yun oil
    ibig sabihin nalilinis ng oil mo yung loob ng engine.
    May 2004
    nung Elf ang ginamit ko mga 1 week bago dumumi. (diesel)
    kaya gustuhin ko mang mag fully synthetic sa aking old skul makina di ko magawa because of longer interval.
    yes thats normal on diesels.
    kahit sa 4jx1 ko paglagay ng Royal Purple dark parin ang kulay.
    (nawawala kasi ang dye ng RP on gas engines)
    sa diesel hindi ..
    use fully synthetic like RP pero the interval would be similar like those on mineral oils.
    ganun ginagawa ko ...
    Nov 2003
    there's no escaping oil getting dirty agad on diesels.
OIL mabilis dumumi
