Results 151 to 160 of 192
- Dec 2013
- 521
July 16th, 2014 04:02 PM #151
- Dec 2013
- 521
July 16th, 2014 04:03 PM #152
- Dec 2013
- 521
July 16th, 2014 04:26 PM #153If Ignition parts hanap niyo, here is the information.
If Hi-Tension wire, buy Seiwa. If your gonna ask, this is the answer: Seiwa's inner ignition wires is bought from an OEM manufacturer in Japan named Fujikura.
They use spiral metallic resistance wire that won't wear out or burn out for a long time in very hot environment compared to those other replacement brands.
If the new type of Ignition system called Pen/Pencil Type Ignition Coil, choose YEC(Yamaguchi Electric Co. Ltd.), they manufacture and design their ignition coil in Japan based on OEMs such as Denso and etc... All the specifications of the car manufacturer are integrated on YEC ignition coils. They are also tested in High temperature durability test and also thermal shock test(from very cold environment to the hottest environtment test)
If Distributor Cap & Rotor, YEC is OEM of Bosch(Germany), Wells Manufacturing Corp(USA), Standard Motor Products(USA), Hitachi(Japan) and Bosch(USA).
- Dec 2013
- 521
December 10th, 2016 12:02 PM #154Sorry for the very late reply, but just to inform the public, RBI is an aftermarket manufacturer of rubber parts that is located in Thailand the quality is not same as the OEM(genuine suppliers) but the price is cheaper but will not last as long as OEM products. 5'826 is an imitation of the Japanese OEM brand 5'825 avoid the imitation as it will not last long and you might have to spend for repairs again which is not economical. For the suspension parts like Ball Joint, Tie Rod End, Rack end and etc... The only available brand in the market which have good quality is 555 it might not be as tough as Genuine or OEMs but its the current best available the color of the packaging is orange with a mixture of red never buy a 555 suspension part with no authorized distributor sticker H or 8.
- Jun 2005
- 3,770
December 10th, 2016 01:25 PM #155^ kung di maganda si RBI? What is the alternative other than original?
Ano maganda brand ng engine support?
December 12th, 2016 11:01 AM #156
may nabili ako na radiator hose...brand name e parang "Titan Rubber manufacturing" sabi...made in philippines ata. around P280 ata bili ko.
- Dec 2003
- 137
January 5th, 2017 10:53 AM #158
- Feb 2011
- 14
- Dec 2013
- 521
February 7th, 2017 05:40 PM #160[QUOTE=sirkosero;2791737]^ kung di maganda si RBI? What is the alternative other than original?
Meron before T.E.(Terada) which is made in Japan rubber bushings, pero since people preferred cheaper price lumabas mga China made rubber parts which is JAG and the better ones RBI which is made in Thailand but not equivalent to OEM ones. Yung mga OEM has a very far price gap than aftermarket ones so they just don't sell to aftermarket.
Ano maganda brand ng engine support? - Either Genuine/Originals or next option RBI, since depende kasi sa kakayahan ng market bumili ang quality or brands ng parts na pumapasok sa Philippines.
