Results 121 to 130 of 192
- Jun 2010
- 321
February 26th, 2014 01:45 PM #121good find!.......kulelat ang vic! ito pa naman ang palaging mabili sa pilipinas, buti na lang baldwin filter gamit ko
- Sep 2013
- 630
February 26th, 2014 03:58 PM #122
So doon sa isang post mo ano shocks absorber na ok bilhin na oem level na, oil or gas?
Sorry mali description ko. Yung lagayan ng trash like candy wrapper na maliit sa likod malapit sa handbrake. Or saan sa banawe ok bumili ng surplus parts na fair price. Kasi mahirap na mabola kaya dapat handa ako pag pumunta.
- Sep 2013
- 630
February 26th, 2014 04:01 PM #123
- Dec 2013
- 521
February 26th, 2014 05:19 PM #124Firstly oil and gas shocks are the same in design except for the gas....
The gas in gas shocks in pressurized nitrogen.
The only use of the gas is to keep the oil cooler for a longer time and therefore keep the shocks valve rate more constant, normally as the shock works the oil heats up and as it does so it thins out, with the oil being pressurized it takes longer to heat up and therefore stays thicker longer. The pressurization has no other "real" effects to the shocker other than make it extend when there is no load apon it
- Dec 2013
- 521
February 26th, 2014 05:28 PM #125If you want standard Gas shocks then yung Super (34/33/36 Series)-Gas Shocks, pero if you want performance then yung mga higher KYB shocks na bilhin mo
Super
Improved handling and performance
Prevents performance fading
Better vehicle control and road holding
Improves comfort and safety
Gas-A-Just
For unsurpassed road control
High levels of comfort & safety
Instantly responds to all driving conditions
Reduces tire and parts wear
- Jul 2011
- 1,711
February 26th, 2014 05:59 PM #126
- Dec 2013
- 521
February 26th, 2014 06:23 PM #127Alam mo naman dito sa Pinas, kung anong mura yun ang patok sa MASA. Kita mo naman pati gasolina natin low octane lang.
What did Volkswagen engineers find in Philippine gasoline products? | TopGear.com.ph
Volkswagen
"We were disappointed when we were told we couldn't bring in our gasoline models," ACE president John Philip Orbeta said. "They said our gasoline fuels are bad."
"They found manganese in some petrol products," revealed ACE sales and marketing head Arnel Doria during a media roundtable at the Manila Polo Club in Makati today. "They use manganese to achieve high octane ratings. It's a substitute for lead and can be damaging to some engine components. Lead has already been banned. Manganese, like lead, also causes ailments that involve the nervous system."
Kaya nga pag sinabayan mo ng bad fuel filter + bad gasoline = damaged engine parts.
- Dec 2013
- 521
February 26th, 2014 06:39 PM #128
- Aug 2012
- 2,767
February 26th, 2014 07:23 PM #129nice share. Purolator ang oil filter na kinabit during my oil change last Dec.
- Aug 2012
- 2,767
March 5th, 2014 08:54 AM #130*JapanABC or sa mga nakagamit na nito, pa-verify naman if this is what genuine Denso Iridium Power IW16 (Made in Japan) looks like. silver color kasi ung body sa box. parang bronze color naman yung body ng actual. i will buy this from Amazon if genuine.
Cabin Air Filtre Carbon activated, interchangeable with 27277-4JA0A/B P190 only. Almost P3k ito...
Nissan Navara NP300
