Results 1 to 6 of 6
- Jul 2006
- 48
August 7th, 2007 05:55 PM #1Tsikoteers tulong naman. My car is lancer gti 91. Just acquired 2 months ago. Lately napansin ko na tuwing i-oon ko yung AC nababawasan ng power , na parang napipigilan yung takbo. Then pag-off ko naman yun para free na uli takbo nya. Have it checked also sa AC shop. Sabi nung mechanic ung idle ko daw bumababa pag on nung ac at di na tumataas (1000 rpm ac off, 500-600rpm ac on). Dati kase tumataas yun automatic pagdrop nya after 2 seconds lang. So kinabitan nya nung idle up switch. Although naremedyuhan ung pagdrop ng rpm pag inoon ung AC, parang noticeable pa rin ung loss of power kung tumatakbo at ioon ung AC. Tapos erratic pa rin minsan ung idle. Nabasa ko sa forum na baka raw servo ung may sira. Totoo kaya to? Ano nga po yung servo? Makakasama ba kung kabitan ng idle up instead na palitan ung servo? EFI nga pala oto ko.
Thanks !!!
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 8th, 2007 08:48 AM #2why not have the intake cleaned and the servo adjusted... it might help...
- Jul 2006
- 48
August 8th, 2007 07:34 PM #3Thanks Speedyfix!
Subukan ko linisin intake, throttle body this weekend...
August 10th, 2007 12:41 AM #4
baka nag-high pressure na yung compressor mo? maingay ba sya pag engage yung aircon?
- Aug 2007
- 246
August 10th, 2007 02:23 AM #5tol, nangyari n di s'kin yan. pcheck mo n din mga pistons mo. bka meron kang cylinder n mahina compression. pero try mo n din muna pcheck yng throttle body and intake. sama mo n rin yng fuel pump kse sa galant nmin dati yun nmn yng barado. ingat lng po s pglinis ng throttle body kze ndyan yng servo. check mo rin yng grounding wires and make sure n nkakabit cla lahat. my sakit kse gti n ngloloko idle pg kumakalas yng ground wires ng electricals. hope this helps...
- Jul 2006
- 48
as an aside, in the olden days, anyone who does not move 'ala luksa during Holy Week, especially...
Traffic!
