Pajero FM. Need help. Here are the symptoms:
1. every morning. one-click start but idle is too low that it dies out at times. if it does not stall, pugak-pugak naman sya.
2. after few minutes, everything works fine.
3. problem happens only in the morning but after office hours, i dont experience the same problem.
4. i started the car late in the morning around 10am today, i did not experience the problem.
I rule out glow plugs because car does not undergo cranking sound during startup. it really is one-click start.
Im no expert in Pajero but try to check (if equipped) a thermistor sensor which is responsible for higher idle while vehicle is not in normal operating temp. Try also to check if there is air and water in the fuel system. Goodluck!
