Well if it is the rotary-type, it may not be lubicated by the engine.
But you are still not out of it, the pump is driven by the engine itself. The SHAFT SEAL is your culprit. It is leaking diesel fuel into your engine.
It is not your nozzles, leaking nozzles cannot fill up the pan that fast because the excess diesel will be moved out of the chamber as very black smoke. Incomplete combustion because the ideal air-fuel ratio will be exceeded.
