Results 1 to 10 of 21
- Nov 2008
- 70
October 26th, 2010 05:46 PM #1Mga sir,
Ano po kaya ang pwedeng gawin sa problema ng auto ko?
Walang IDLE or menor. But kapag tumatakbo, ok naman ang performance, not until apakan ang clutch and bitiwan ang gas pedal, bagsak ang rpm diretso hanggang mamatay engine.
Initially, up and down ang idling then after a few days, nawalan na totally ng menor. Had to keep stepping on the gas pedal.
Already replaced sparkplugs
Car is an 89 Nissan Maxima, CA20s engine *carb*
TIA
- Apr 2009
- 1,902
October 26th, 2010 05:51 PM #2Check the idle adjust screw.
Sometimes carbs (particularly on the fuel mixture) get out of tune especially on frequent changes in atmospheric pressure and temperature, as per experience.
Lest your air filter is damn too clogged and carb is damn too dirty/sludgy that they call for a clean or a fix.
October 26th, 2010 05:54 PM #3
What gasoline you using?
And when was your last air filter change/cleaning?
- Oct 2010
- 9
October 26th, 2010 06:04 PM #4Meron ka bang ginalaw sa makina recently? Like gusto mong bumaba ang idling?
Ibig bang sabihin ay kailangan mo parati ilagay ang paa mo sa accelerator para hindi mamatay ang makina?
palagay ko hindi sa clutch ang problema ... palagay ko sa pag alis ng paa mo sa gas kaya namamatay.
1. masyadong mababa ang idling mo. ang kotse ay normally nasa 500 to 600 rpm at idle. check mo yung cable papuntang idle at baka may gumalaw or may natanggal na pinagsasabitan ng cable, you have to put it back.
2.kung 89 model yan, may carburador ba yan? check mo din at baka ang combination ng hangin at gas ay hindi tama. Nagpalit ka na ba ng air filter?
I hope this will help/
have fun driving
- Nov 2008
- 70
October 26th, 2010 06:36 PM #5Already tried adjusting the idle screw, same pa rin
Will try to get a carb cleaner within the week, medyo restricted sa oras due to work
I use either XCS or GOLD (caltex), and minsan yung sea oil yata yun na 97%
a month ago yata yung last air filter cleaning ko
originally, idling ko was set to 700-800. Wala naman nagalaw sa makina, except for the sparkplug replacement last september
Yup, carbed type engine. We tried changing the setting nung fuel/air mixture, and correct me if I'm wrong, this is done through the screw thingy na may spring sa lower side ng carb? no change after tweaking the said screw
*ALL
Kahit wala yung air filter same pa rin ang nangyayari
additional question, I attached a pic of my extra carb and manifold, does the highlighted part needs to have some sort of hose attached to it? if yes, san ito nakakabit?
kasi napansin ko din na kapag wala takip yung butas, sagad sa taas yung pin that adjusts idling, pero kapag nakatakip, may pressure yung pin
- Apr 2009
- 1,902
October 26th, 2010 06:59 PM #6Have you checked the PCV valve hose connecting to the carb intake?
Sorry I can't see you pic (on restricted office view) but hoses and tubes have to be either connected somewhere or closed sealed.
I had a similar dilemma on my carb when I disconnected that hose, which is sometimes prone to be accidentally disconnected.
- Nov 2008
- 70
October 26th, 2010 07:09 PM #7
October 26th, 2010 07:11 PM #8
Petron XCS already have ethanol mixed into it. Not sure about Caltex Gold.
E10 gasoline might be causing part of your trouble. Carbs & ethanol don't mix well.
You might want to try Petron Blaze or Total Protec because that has no ethanol mixed into it.
- Nov 2008
- 70
October 26th, 2010 07:17 PM #9
October 26th, 2010 07:25 PM #10
