I have a 4k gas engine, newly topoverhauled, normal lng b na mtaas ang temp? mga 7kms lng from work to my house ang tinakbo.
depende,eh kahit pa isang kilometro lang ang layo ng work mo,kung matagal naman nakaidle ang makina eh talagang tataas yan at yan ay normal.pero ang tanong kung gaano kataas ang temp nyan? at kung nagoverheat ba?
Oo naman! Normal operating temperature takes about a minute or so while driving from the very first you start your car. So depende sa sinasabi mong tumataas, if it is overheating then there is something wrong. Before removing that head again check everything from coolant, hose, water pump, radiator, thermostat, leak etc...... Isolate those before doing drastic speculation.
hi sir,
How hot is hot? hehehe for my car 4-afe, middle of C & H talaga. in 5 mins or so andun agad yun kasi may thermostat pa.
Thanks, hindi naman ng o-overheat, before ko inistart ung engine kanina, pinalitan ko yung tubig sa radiator, tapos sinilip ko nung naka idle ng boboiliong naman, Di ko alam correct term for that. Tapos nung pinatay ko ung engine sinilip ko ulit yubg radiator, parang may oil sa ibabaw. Ok lang ba iyon?
naku, yan ang hindi normal at isa lang ang ibig sabihin nyan,may internal leak ang makina.maaring busted yung head gasket o crack sa engine block o crack sa cylinder head.or maari ring excess or spilled oil lang yan mula sa pag overhaul nila.
ang gawin mo muna,ioverfill mo ang radiator ng coolant or tubig hanggang sa mawala ang oil and then paandarin mo ang makina hanggang sa uminit at hayaan mo siyang magoverflow then takpan mo,at hayaan mong nakaidle to normal temp,then turn off mo at palamigin.then check kung may oil,kung wala na then your fine,kung meron naman at sa palagay ay dumami yun na yung unang nabanggit.
check mo yung cooling system hoses kung malambot na malabot na ba,yan din ang indication ng oil leak to cooling system.
check mo rin yung oil kung milky ba.
check mo spark plug kung oily ba.
marami oil ba? baka naman it's just from a dirty mechanic's work contamination.![]()
Pina top overhaul ko last week ung 4k gas engine ko, kasi palagi akong napupundihan ng #1 sparkplug. One week after, napundi uli ung same sparkplug. Pinalitan ko ulit? What seems to be the problem? Tsaka napansin ko pag medyo paahon ng konti ung daan, galing me sa 4th gear di kinaya, so ng 3rd gear ako, hindi pa rin ng 2nd gear, hindi pa rin. So nag 1st gear ako parang mamatay ung engine. Umatras na lng ako. Kumuha uli ng buwelo. Bigla kasi my huminto na sasakyan sa harp ko nun, e natyempo na paahon ung daan.
quick check ka muna;
check mo ang oil kung color de gatas na ba.
check mo coolant kung may oil ba.
check mo ang spark plug kung amoy gas,oil or coolant.
kung pwede mo picturan,gawin mo yung pagkatanggal para fresh sya sa picture and ipost mo dito,mas maganda kung nakahilera ang spark plug (1234) and im sure maraming sasagot sa tanong mo.
