Results 11 to 14 of 14
- Feb 2015
- 5
February 12th, 2015 03:14 PM #11bka po may idea k u kc lagat ngawa at npalitan ko na kaso pang ahon ang takbo ng kotse ko tumataan temp nia
- Feb 2015
- 5
- Feb 2015
- 28
February 26th, 2015 09:29 PM #14I do not speak bisaya so i will try to expalin what i think has happened here in english.
Your radiator probably was blocked, and most likely this was caused by the use of water. If you have a decent pressurised cooling system, you MUST use a proper coolant for 2 reasons.
1. Coolant doesnt expand when heated (will not boil out the overflow hose through the radiator cap unless it really needs to)
2. Coolant doesn't contain iron or other detrimental elements that will block up the radiator.
It sounds as if the radiator technician did repair the radiator, but you need to use coolant, and the coolant needs to be bled into the system, not just poured in and start engine and off you go.
It would have appeared to be full to the mechanic but their would have been a lot of air still in the coolant passages around the cylinder head, which are now full of water, and that air has now exited the system and the total level has therefore dropped.
You need to find a decent mechanic with respect for the cooling system who knows how to refill the system.
Let us know how you go!
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
