Results 11 to 15 of 15
- Jan 2008
- 380
March 24th, 2008 01:47 PM #11Yung lumang-luma kong kotse nagkaganyan din pero swerte naman at makapal na carbon lang pala sa exhaust sytem na na-saturate ng tubig naidaan kasi sa baha. Linis, palit tambutso at takbo lang yung kotse ng medyo malayo. Di na rin umulit.
Wala ba oil leaks engine mo excessive blow-by or oils sa paligid ng valve cover.
Pero di ka naman maghihikahos sa Top Overhaul, PM mo na lang si sir speedyfix bago lumala problema car mo.
- Jan 2008
- 42
March 26th, 2008 11:33 AM #12Tnx mga boss
is it possible na baka pwede change oil lang siya kasis last ko pong change oil is last year october pa
- Jan 2008
- 42
March 28th, 2008 12:35 PM #13This only happened once when we went up to antipolo with 5 passengers with me . the next day when i've tested it walang usok ive tried it the second time wala parin usok nag rev ako ng nag rev wala parin usok . Pretty strange di ko na talaga tuloy alam kung bakit ganun siya
still need help just to make sure that it wont happen again or to prevent it from happening
March 29th, 2008 05:36 PM #14
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 3rd, 2008 09:21 PM #15it might have to be checked so you can say for sure what the problem is. mas mabuti kung makita ng mechanic what is wrong and tell him the symptoms/problems so that they can check specifically for that
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
