Results 1 to 15 of 15
    Aug 2006
    Quote Originally Posted by zach09 View Post
    This only happened once when we went up to antipolo with 5 passengers with me . the next day when i've tested it walang usok ive tried it the second time wala parin usok nag rev ako ng nag rev wala parin usok . Pretty strange di ko na talaga tuloy alam kung bakit ganun siya
    still need help just to make sure that it wont happen again or to prevent it from happening
    nagkaka white smoke pag cold start? or pag matagal na ginagamit?
    1. try to check if nagbabawas yung oil mo
    2. try mo pa compression test kay sir speedyfix, mura lang yun, para malaman kung ano possible problem..
    HTH...
    Nov 2003
    it might have to be checked so you can say for sure what the problem is. mas mabuti kung makita ng mechanic what is wrong and tell him the symptoms/problems so that they can check specifically for that
Need help Excessive white smoke
