Results 21 to 27 of 27
- May 2005
- 20
- Apr 2005
- 20
April 22nd, 2007 02:52 PM #23Maliit na talyer lang sa harap ng lumang Ever Gotesco mall along Alabang-Zapote road. 7k lang total ang nagastos ko sa overhaul, 4.5k parts + 2.5k service.
May 11th, 2007 03:43 PM #24
hi peeps! need ur advise on this, revo EFI 98 model -118,000km odo... is top overhaul (machine shop) the ONLY SOLUTION pra makuha ung half ng spark plug na naiwan sa socket hole nya. naputol kse ung spark plug while in use ung oto, tas ung threaded part lng ang naiwan sa loob. dinala ko sa RAPIDE and their charging me : 4,500 for pull down ng engine and reinstallation, 7,200 for machine shop (includes valve setting,valve seat reface,lapping,hydrautest,steam wash) plus 1620 changeoil,filter , spark plug.sabi nla since ioopen ung cylinder head might as well do a top overhaul. wat do u think? appreciate ur response..
May 12th, 2007 05:24 PM #25
Try to bring it sa machine shop mismo. It will depend how deep the spark plug hole is and the remaining part inside. They can use a reverse extractor tap or they can spot weld the remaining plug and turn it.
Did it once on a broken cylinder head bolt on a engine block that is still mounted. Syempre inalis ko muna cylinder head. Sa Roque Machine shop si Boss Mario ang napakiusapan ko. Towed it first thing in the morning by lunch time i towed it back.Last edited by 4JGtootsie; May 12th, 2007 at 05:27 PM.
February 20th, 2014 08:54 PM #26
Buhayin ko lang po ang thread na ito . . .
Finally, my engine has to be overhauled. Dukot ang gusto ng "family friend" mechanic ko pero I was the one who opted the overhaul done. Ang labor nya ay 7k lang. Sa mga pyesa po ako nangangailangan ng advises nyo . . .
What is the best non-OEM (aftermarket) overhauling kit for Mitsubishi (or any car brand)?
TIA!
- May 2014
- 10
May 15th, 2014 05:13 PM #27Gud Day mga Bossing,, I have this van mejo old na ang Toyota TownAce 1998 model, this year lang e nagkaproblema ako kasi nag overheat xa while im Driving NLEX going to SanFernando , nag stop xa then thankfully kahit papano naka uwi naman ako, lately pina check ko xa need for overhaul then nawalan ng Reverse puro forward lang , nai suggest skin is for change engine and tranny, 2c diesel engine automatic , ask ko po mga bossing saan kaya merong mabibilhan ng ganung engine at magkano kya ? Wla kasi akong idea how much the entire engine and tranny ng 2c automatic .. please need info mga Bossing.. Thanks
Suzuki JIMNY [merged threads]
