Results 21 to 28 of 28
April 28th, 2003 04:33 PM #21
since A/T naman car mo medyo di naman masyado masama sa kotse....magagaling na computer ngayon! :mrgreen:
as posted earlier, meron namang rev-limiter at auto shift naman agad to a higher gear to prevent "undesirable engine conditions". and it is desirable to drive your car HARD .....ONCE IN A WHILE (key term :lol
ingat lang sa hard driving mga boys and girls, a friend of mine accidentally downshifted from 5th to 2nd at high rpm......KABOOM!!!! 8O
- 197
May 3rd, 2003 11:12 AM #22vinj,
Iba pa ba iyon sa German tune-up?
I remember reading an article about Porsches, and they had a model (pre-911) that always fouled its plugs, so they really had to rev the engines hard to clean the carbon deposists so the plugs would not foul completely.
I do this at least once in between fill-ups.
May 4th, 2003 01:45 AM #23
dont worry about hitting the redline, meron namang fuel cut-off so bago lumipad ang pistons and rods mo from your hood, eh kakadyot-kadyot ang car mo na para bang palyado. nagawa ko na yan sa old teg ko, 8k redline ko but while going 75mph on a 5th gear, down shift ako ng third pero medyo nalingat ako at di nakita na lalalagpas na ng 8k rpm. 3rd gear 8.2k rpm, kadyot kadyot na teg ko na parang walang ibubuga. :lol:
saka ang Honda, meant to shift right before the redline :mrgreen: and A/T naman car mo so dont worry, let the tech deal with it. hehehe
May 4th, 2003 01:08 PM #24Originally Posted by RS Sprint
May 4th, 2003 02:06 PM #25Originally Posted by sHoCkAbSoRbEr
- 197
May 4th, 2003 03:27 PM #26Basta lang wag mo papaabutin sa fuel-cut, ito and masama sa wear and tear ng makina. On 4 cylinder engines with longish strokes (like Mitsu 4G63) may mga instances na naputol ang conrod kasi nabigla yung tigil ng momentum ng pagikot ng crank at rods.
Pero mati'c naman eh so unless iiwan mo sa 2 or something, hindi siya aabot sa fuel-cut.
- Mar 2003
- 91
May 4th, 2003 07:36 PM #27hmm.. driving ng lagi mo nlang pina pa cutoff can shorten ur engines life.. fried agad piston rings niyan.. & bka mag loose compression ung auto.. agad
- Jan 2003
- 611
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
