Results 11 to 16 of 16
- Mar 2012
- 26
August 4th, 2015 10:54 AM #11Tapus eto pa yung fuel indicator nun pinasok ko is just below the half mark. Tumawag sa amin si toyota at sinabi na wala na daw diesel at umilaw na yung fuel low indicator. Nag papaalam na mag kakarga sila ng 500 pesos worth ng diesel to continue the "TEST".
Nag taka ako panu mauubos yun?
Ayun after ng ginawa nila napsin ko na yung mga leaks and mababang f.c.
August 4th, 2015 11:18 AM #12
Try another dealer. Tell them the problem.
New air filter (intake), should've improved your FC actually.
- Jul 2013
- 2,450
August 4th, 2015 11:22 AM #13
- Mar 2012
- 26
August 6th, 2015 12:22 AM #14Thank you po.
Ngayon sa toyota pasig na kame mag papa maintainance.
Actually di ko pala na check kung saken ba talaga yung air filter. Baka kinuha nila sa ibang innova na nagpapa pms.
- Oct 2014
- 5
October 8th, 2015 11:23 PM #15Good Evening Po.
Meron din ganito ang innova G diesel ko. Nakapag papalit na din ako sa Toyota Casa pero ganun pa din may tagas!
May advice po ba kayo ano root cause nito. Thanks.
- Oct 2014
- 5
October 8th, 2015 11:23 PM #16Good Evening Po.
Cabin Air Filtre Carbon activated, interchangeable with 27277-4JA0A/B P190 only. Almost P3k ito...
Nissan Navara NP300
