Results 1 to 3 of 3
May 25th, 2012 09:47 PM #1
Hello fellow tsikoteers, ask ko lang where to start, may natengga kaming sasakyan
Toyota ee90 with 2e engine, plan ko to restore sa stock, anu kaya magandang gawin muna sa engine bago ko istart ulit? Plan ko muna icondition yung makina, clueless talaga ako although may alam naman ako sa maintenance ng sasakyan, ayoko lang magkamali help, thanks
May 25th, 2012 10:02 PM #2
From the top...
-drain and replace all the fluids (motor oil, power steering, brakes, radiator water, etc)
-replace all the belts, oil filter, air filter, fuel filter, radiator hoses, radiator cap.
-by hand, check if the engine still turn or is it seized (if seized, you'll need to have it overhauled)
-replace the sparkplugs, check if the sparkplug leads are cracked. Replace if necessary.
-replace the battery. Check the electrics for any warnings or loose wires hanging or cut or bare wires (rotted or eaten insulation)
-check for vermin infestation and potential damage due to rats/mouse.
-replace the old stale fuel with fresh gasoline. Flush the system out until fresh fuel comes out at the engine side.
Start the engine.
You might be better off letting an experienced mechanic do the work.
Monk-owned R53
