Results 11 to 17 of 17
- 152
April 24th, 2003 11:48 AM #11di ba pede din hi tension wires ang culprit pag palyado? nakakaapekto ba ang mahinang battery sa idling? erratic idling?
- 38
April 24th, 2003 12:35 PM #12Nung paayos mo yung carburetor mo, overhaul ba? Kasi nangyari na yan skin before tapos pina overhaul ko yung carb umayos na.
May 8th, 2003 03:26 PM #13
mr bangis,
pa check mo rin ang fuel line baka barado. na experience ko rin yan at nagawa ko rin lahat ng pinaayos mo at ang last tingen ko kapos ang kuryente baka sira na ignition coil kaya nag palit ako ng bago kaso ganuon parin kaya hangang sa itirik ako at pa on ko ulit mga 100 meters palang tirik na naman...
pinabomba ko lang yung fuel line na intake going to fuel pump then going to curb. pag barado kase kapos ang dating ng gas sa curb. after na pinbomba ko until now k parin pero the best thing is pa linis ko yung fuel tank pero isasabay ko na pag nag pa body repair ako.....
god bless all!!
- Nov 2002
- 70
May 9th, 2003 02:03 AM #14Try having your vacuum lines check leading to your intake. This may be the culprit....
It happened to me once with my Mitsu. Two vacuum lines where switched.... or check your carb & fuel filter....
RIDE ON...
May 9th, 2003 07:42 PM #16
palagay ko nga, clutch system na kaya nag iipon na ako. San kaya magaling gumawa nito at mura, plus yung parts na ok?
- Oct 2005
- 72
October 17th, 2005 04:07 PM #17mga bro please help me iyong idling ko nag up and down pag naka on ang A?C pero
pag nakaoff normal na man.
do you thnk this need to clean the throttle lancer A/T EFI
please help me to have idea thanks
^ geo yatta of bulacan, ang nagcause ng traffic sa NLEX eh hinid minimum wage earners. Mga...
Traffic!
