Guys,
Left the other car for a 3 day vacation, last time I used it was for a 10 minute warm-up. I got back, it won't start.
Guys,
iam3739.com
if its crancking? check the fuel pump and fuel filter..gasoline engine?
why the title po? napatignan mo na ba cia sa mekaniko? ito ba findings nia?
nalunod b ng gas? tangalin po yung airfilter para para magkaroon ng air and fuel ratio tnx
ayaw mag start,walang ridondo ba ibig mong sabihin? pag hindi nagriridondo ang engine,battery yan. nadiskarga siguro ang battery mo.
jump start lang yan kung na-drained yung battery. tapos kakarga na yan once mag-start na.
Guys salamat sa reply.
nagtatampo siguro tong isang kotse kasi madalas ko ginagamit yung matipid.
nalunod daw sya ng gas. Check ko gawin yung mga snabi ninyo, okay pa naman batteries.
iam3739.com
paano malulunod if you don;t step on the gas pedal? iniwan mo nga diba? unless you kept on stepping on the gas nun hinde ayaw na mag start
Baka napuno ng gasolina yung carburador? Maybe because the accelerator cable got stuck?![]()
hindi nga malulunod yan unless you keep starting it. but even then the plugs should be able to start the car. you might wanna have it checked nalang by a mechanic.
