Results 1 to 10 of 11
June 9th, 2004 02:11 PM #1
i dunno how to put this situation in the subject. This always happens.. pag pinatay ko na yung auto.. parang naiiwan pa ang makina or delayed na mamatay sya... normal ba ito? i was thinking that when i turn off the ignition, eh sabay patay din ang makina.. pero naiiwan eh.. sandali lang pero worried lang ako sa delay. thanks in advance.
June 9th, 2004 02:19 PM #2
Your engine needs to correct its timing. Kung carburated engines, may dumi minsan sa loob. Pero dapat pag takbo nyo pumupugak ang makina.
Kung wala naman backfire or sinok ng makina habang nananakbo, timing adjustment lang po baka masolusyonan na yan.
- Sep 2003
- 43
June 9th, 2004 02:45 PM #3kala ko naiiwan ang makina mo kapag nag-ooffroad gusto mong palitan ng malakas hehe...
- 267
June 9th, 2004 02:48 PM #4dieselling or pre-ignition ang problema ng makina mo. Give your car a major tune-up. Make sure your using the right spark plugs of correct heat range for your engine.
Pag di pa nakuha at de carburador yan, pa check mo yung fuel cut solenoid valve. Baka stock up.
Pag di parin makuha, you need to decarbonize your engine. Excess soothe deposits in the combustion chamber acts as glow plug, kaya nag pepre-ignition.
June 9th, 2004 02:59 PM #5
saan ba may nagde-decarbonize ng engine?
minsan ganyan ang tsikot ko, bumabalik ang kilig ng makina maski tuned-up at adjusted na timing. mahal ba yun?
June 10th, 2004 11:30 AM #7
any shops you recommend for this kind of stuffs? thanks for the input otomatic. btw, i recon having a tune-up sa casa (mitsu), would you recommend any other shops (sir speedyfix , pwede po ba ito sa iyo?) alam nyo na, mahal sa casa, kung makakakuha ako ng parehong service (casa or not) eh dun ako sa mura
June 10th, 2004 11:35 AM #8
hindi naman "maling pagtitipid" ito guys right? or having a tuneup in a casa is something na hindi kaya sa labas (which i doubt - madaming magaling na mekaniko sa labas)
June 10th, 2004 11:58 AM #9
kung routine tune up lang hindi mo na kelangan ang casa. come to think of it, hindi mo naman talaga kelangan ang casa as long as you know where the good mechanics are
- Mar 2004
- 252
June 10th, 2004 12:15 PM #10yeah i think pareho lang... mas okey sana kung may kakilala ka na sa casa nag wo work then nag sa sideline pag after ng work nya sa casa... di ba ok yun ???
