Results 21 to 27 of 27
- Feb 2013
- 42
May 22nd, 2013 03:01 PM #21
May 22nd, 2013 08:27 PM #22
ok pero pag trade in wag mo sama yun mga parts na imporatante like starter, alternator, compressor & injection pump medyo mahal din kasi yan pag binili mo na.
May 22nd, 2013 10:46 PM #23
do a cost analysis...
how much would you be spending if you had your engine Oh'ed where you can be sure that all of its components are new
versus...
a surplus engine where you will not know its condition and may conk out after a year or so.
May 23rd, 2013 09:55 AM #24
I agree here. I'm in the same situation with a Camry i'm working on now. It overheated and there's a possibility the cylinder head warped. Toyota of course will charge 300K+ for the job when it was assessed at Toyota Shaw Pasig (new engine or new engine block); Options are to either have the cylinder head done at a machine shop and do a top overhaul (new gaskets) or look for a surplus block (which is pretty hard to come by for a Toyota 2.4L engine) then recondition the engine on top of it.
- Feb 2013
- 42
June 16th, 2013 10:54 PM #25Helo.update lng po sa sasakyan ko.hindi ko na pahabain ang kwento basta nailabas ko lang kanina sa shop at ok na siya.ito ang inabot sa gastos,
:surplus cylinder head assembly(di na kasi pwede na mareface daw sa machine shop kc ang laki nang benkong at may mga bitak na daw)=16,000
Cylinder head gasket=975
Timing belt=700
Shaft oil seal=80
4pcs surplus nozzle(injection pump)=2000
Change oil=1260
Labor=2,500
TOTAL=23,515
Salamat sa pagbasa.God Bless
- Apr 2010
- 268
June 16th, 2013 11:19 PM #26
- Feb 2013
- 42
June 17th, 2013 06:28 AM #27*thesheperd-nagkataon my pinsan po ako my negosyo dito sa amin autosupply,surplus shop dati direct importer pa ciya sa japan mga surplus parts at saka may sarili na rin ciyang talyer kasi may transport services din ciya(7 fx taxi at 4 na bus pamprobinsia).kaya yun walang iba sa amin kaya malaki discount ciguro hehe.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
