Results 1 to 10 of 10
BANNER BANNER BANNER
- Jun 2008
- 1,439
December 4th, 2008 01:10 PM #1Is it possible to install simple engine mods on the Innova with the 1TR-FE 2.0L gas engine? I've heard of free-flow air filters, but nothing else. Also, if I ever install a free-flow air filter, is the performance gain easily noticeable?
I've done 180km/h flat-out (designed speed is 185km/h), smoked a 3.0 Fort, but it took a very long time to reach that speed. I'm aiming for better acceleration. Will the air filter do the trick?
What other engine mods have been already done on the 1TR-FE?
Hoping for your replies.
- Sep 2007
- 215
December 4th, 2008 07:42 PM #2change for better oils and get a better kind of spark plugs ... air filter will just increase your throttle but not the burn
- Jun 2008
- 1,439
December 4th, 2008 10:04 PM #3That's a thought! As of now it's filled with Mobil 1 fully synthetic (10w30 I think). Are there other spark plugs out there with the same size as the stock Denso's? It's longer and has a smaller diameter compared to "standard" spark plugs.
December 5th, 2008 12:01 PM #4
No plug will be better than stock, unless there's a redesigned plug specifically for your engine.
It's all in the tip design, as the stock plugs have the proper length and height to put the spark in the center of the combustion chamber. If you can find the platinum version of your stock plugs, that'll last longer, but performance gains will be negligible.
Exhaust modifications should do wonders for a gasoline engine. Beyond that, if you like driving quickly a lot, you should look at getting better tires (preferably on wider (not necessarily taller) mags).
All other power modifications cost money. Fuel management, turbocharging, etcetera.
December 5th, 2008 11:43 PM #5
bro rims nalang tpos keep it stock but always in tip top condition, tignan mo ako bago palng car ko tpos kung anu na ginawa ko napasubo na ko kaya no choice kelangan matapos ng maayos,.. sakit na ng ulo ko kakaisip kung anu ba maganda.. huhuhu...
August 26th, 2011 12:06 PM #6
roberto, i hope u r still here. I used k & n filter and 205/55 r16 tires only. the difference is very noticeable.
- Jul 2011
- 584
August 26th, 2011 12:17 PM #7*amil
Re: K&N filter sir how long nyo na ginagamit? na inspect nyo na po MAF sensor nyo na co-contaminate ba nito talaga ng oil ng K&N? yan kasi nababasa ko nega about K&N filter, curious lang po kung totoo.
August 26th, 2011 02:00 PM #8
And then a higher-flow air filter would also make some more sense than just throw it away...
But I would still not to disconsider a turbocharger with an intercooler (or maybe a JWAC).
- Jun 2008
- 1,439
August 26th, 2011 04:45 PM #9I kinda lurk a lot nowadays . We kinda lost interest in getting a K&N filter, coz we don't use the car really often anyway. I got a knock-off OEM replacement air filter for really cheap a few months ago, and it's still good. No effect on the performance. I would've bought a K&N drop-in while I was in the US, but dad wasn't interested so I passed up.
And if anyone's interested in making the TR series go really fast, you might wanna check out these links:
Atomic's Tacoma Turbo system
2.7 vvti alpine developements supercharger - Tacoma World Forums
August 26th, 2011 05:08 PM #10
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
