Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
    Aug 2004
    #21
    Quote Originally Posted by neozeke View Post
    oh i see... thanks for the suggestion guys...
    do you have suggestions kung saan ung best na naguupgrade ng Intake, Headers, and Exhaust??? thanks...
    Mufflerland does good work.
    Remember, though... the more you modify the exhaust, the higher in the rev range your peak power will be... which means some compromises, given the automatic transmission.
    Apr 2011
    #22
    +1 sa Mufflerland. Pulido sila gumawa and mayroon sila Mandrel bender. ganda ng mga pipes na Mandrel bent. Tapos Tig Weld gamit nila pag dugtong ng pipes so ang linis linis tignan.
    Jul 2006
    #23
    thank you mga sir... though ilang araw or oras before magawa ung buong system??? thanks...
    Jul 2006
    #24
    Quote Originally Posted by airolynx View Post
    how much po usually ung charge nila??? thanks!!!
    Nicely said Niky! galing talaga!!!
    *TS, if you want to play on the "safe and tipid" side, i'd say go for upgrade IHE (Intake Headers Exhaust) on your stock engine. This at least is a little less invasive. It will give you a slight power gain. Pero kung gusto mo nga ng talagang oooomph, change engine is the way to go.
    You can also opt to change your spark plugs and Hi Tension wires to split fire.
    Econo upgrade ika nga. :D hehehe di ko lang alam how much 'gain' you will gain from this...
    Kaya nga master yan si boss niky eh. hehe
    #26
    Depends. Usually it takes them less than a day to finish a job.
    Aug 2004
    #27
    Master... na mabait? Master-bait?
    Mufflerland, should cost you around 25k+ if you do the entire system. For an AT, you might want to just start with the midpipe and muffler.
  8. #28
    remeber sa AT at city/daily driving beneficial kung may low at mid end torque ka.. kung highway driving, best kung torque mo ay nasa mid to high range naman... kaya kung papalit ka ng makina consider your usage....
Modifications for an A/T engine
