Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Apr 2006
    i want to top off my engine oil kasi medyo mababa na siya.
    i know currently it's fully synthetic royal purple. let's say ang idadagdag ko is mineral lang and not of the same viscosity. at most a quarter liter lang siguro as a temporary fix until i have my oil change.
    would this hurt my engine?
    Aug 2005
    Quote Originally Posted by wewoy_romero View Post
    I think it is bad to mix synthetics and mineral oils. kahit na pang top off lang ang mineral oil.
    Jul 2006
    Is it just below the max line? You should be fine if you're in between. If you frequently go below the minimum line then I think you should have it fixed before using synthetic, otherwise you're just wasting money.
    Instead of basic mineral oil why not just use a synthetic blend? That way it's closer to the synthetic type but cheaper, make sure you use the same viscosity and rating (S or C rated).
    Apr 2006
    it's still above the minimum line. around 25% midway between the minimum and the maximum levels sa dipstick.
    medyo nakaka-worry lang talaga. anyway, due naman na for oil change.
    Jun 2006
    kung above the min line and due for oil change ka na, pa service mo na para isa lang gastos.
    kung synthetic ang nakalagay, imo same blend na rin ang idagdag mo para maiwasan ang problema if ever di nga mabuti magkahalo… kung malapit na rin ang sched oil change better palit na lahat at mas maige kung ma locate na rin pati ang leaks.
    imho, if you are topping up, make sure you use the oil with the same viscosity. it does not matter what brand, but what is more important is the viscosity.
    Sep 2004
    According to RP website, their oil is compatible with most kinds of oil, even mineral oil.
    May 2007
    what if not topping up.. total change oil talaga na magkakaibang brands?
    meron kasi kaming mga tira tira ng mga gallons from recent oil changes pero iba ibang brand..\
    me problema kaya lung same lang ang viscosity at puro mineral oil naman lahat?
    May 2007
    Quote Originally Posted by 1D4LV View Post
    TWO THUMBS UP!
    Are you checking when the engine is cold before start up? If that's level you have when it's already warmed up then you should be fine, and even if it was cold you should still be fine as you are still above the minimum line anyways.
    Sep 2004
    Different manufacturers might have used diff. additives that could react with each other.
    It is better to use oils from a single manufacturers for compatibility.
    Apr 2006
    i'll just leave it be muna. a few hundred kilometers na lang naman due na for changeoil.
    Nov 2003
    if you've got to top up just do so with the same viscosity full syn oil.
    Sirs,
    makikisakay na lang din ako, hope you won't mind. I was wondering when would I do a change oil? I am presently using 10w30 synthetic oil - Mag1 brand. I am doing at least 10,000 kilometers a month. Pwedeng every 3 months? 6 months? Your suggestions please. .
    Apr 2006
    Quote Originally Posted by mazingerZ View Post
    Sirs,
    10,000 kilometers a month? whoa! :jawdrop: you should do a changeoil every month kung ganun.
    kahit naka-synth ako, for peace of mind i still do the 5k changeoil if my budget permits.
    *speedyfix
    see you soon for the changeoil. pa-check ko na rin kung may leaks (feeling ko malutong na yung gasket).
    Aug 2005
    Sirs,
    10,000 Km per month. Grabe! Taxi ba?
    pag 10,000 per month, monthly ang change oil with change ng oil filter every 5,000 Km
    Sir,
    Mali pala computation ko, its around 2,100 kms a month ( 85 kms/day x 6 days a week). Hehehe . . .
    Aug 2005
    Sir,
    Sa Toyota pag mineral oil ang gamit mo, change oil every 5,000 or 3 months which ever comes first.
    Sa akin, slightly more than 2 months lang ang 5,000 Km.
    Sir,
    it's 4k+ kms in 2 mos? with a fully synthetic, better to schedule an oil change every 8-9k kms regardless kung ilang months na.
mixing different engine oils
